Sponsored by:
Sponsored by: CARiD
2010 Evo X Tint -scratches?
Old Apr 16, 2010 | 08:10 AM
Volkerball's Avatar
I got my windows tinted 2 weeks ago. I see that 08 Evo's had tint scratching problems, do the 2010's have the same issue?
Old Apr 16, 2010 | 08:12 AM
Sufu's Avatar
My guess is yes. It's like 30bux to get the felt, I think it's worth it so you don't scratch it to hell.
Old Apr 16, 2010 | 08:14 AM
total0wnage's Avatar
i wouldnt doubt it, next time i get my tint done im not gonna make the mistake of not having the felt installed cause mine got scratched up pretty bad
Old Apr 16, 2010 | 08:24 AM
Webman's Avatar
Funny, everyone else talks about scratching, but I don't have that issue. Not on the Evo, nor on my 2009 Lancer GTS.
Old Apr 16, 2010 | 08:25 AM
atombomb33's Avatar
EvoM Community Team
Just feel the inside lining of the rubber separator between the window and the inside door panel. If it's all rubber, then it will scratch. If it's soft, you'll be fine.
I put the felt "moleskin" on my windows to protect the tint. It worked great.
http://www.tintprotector.com/mitsubishi/index.htm
Old Apr 16, 2010 | 09:32 AM
lancerarmstrong's Avatar
i know for a fact that they fixed this in the late 2009 model GTS's, so on the 2010 evo my guess is yes they did fix it. to be sure, after you take off your door panel you can just take the plastic part that rubs on the window off and look to see if it's soft or hard plastic. they were supposed to change it to a softer plastic or put felt on it from the factory
Old Apr 16, 2010 | 10:54 AM
Evostare's Avatar
YES, they do have the same issue. I had my windows tinted for about 5 months, after those 5 months my tint had streaks the size of canada.. super annoying seeing how it cost me 200 dollars. My fault considering i never installed moleskin. I ended up ripping it off and keeping it with no tint.. It actually looks better too..
Old Apr 16, 2010 | 03:02 PM
SMURF 1's Avatar
did this also and fixed the problem
Old Apr 16, 2010 | 03:45 PM
abazaba410's Avatar
yeah i was told it wasnt a problem then it happened to me
Old Apr 16, 2010 | 03:54 PM
Spy007's Avatar
i only have 1 window that this is an issue with... and its my rear passenger window. Since i have plans for it... it will be fixed anyhow later
Old Apr 16, 2010 | 04:17 PM
monkey_187's Avatar
I wonder if its the tint brand? I have LLumar and my passenger rear makes noise but has no scratches on it. What brand of film do you guys have?
Old Apr 16, 2010 | 04:18 PM
aftershock141's Avatar
I have mole-skin glue all over my tint haha...oh well.
Old Apr 16, 2010 | 04:54 PM
JaCe's Avatar
Definitely need the felt. It came standard on Aussie spec models after people complained I believe- my 2009 delivered model had it already.
Old Apr 16, 2010 | 10:46 PM
Paul000's Avatar
Question Window Tint
What brand did you use? You should probably let you tint installer solve the problem. I also got my evo tinted very recently and I never had problems with the tint. I consulted the expert on tints at www.TintBuyer.com for my window tinting needs, they provided quotations, tint law in every state and locate the best professional tint installer near my area.
Old Apr 17, 2010 | 01:33 AM
EndlessRed's Avatar
this.
*sigh*
always used goo-gone to clean it up. quite annoying.
on top of that my front driver window still scratched. probably from some dust stuck under the felt and the glue holding it in place second time it happened too.
