Sponsored by:
Sponsored by: CARiD
Narrowed down list for intake and turbo-back, but still can't decide.
Old Nov 6, 2010 | 08:10 PM
  #76
nj1266's Avatar
Originally Posted by oftheheavens
this is not true. my drop in didn't effect the trim at all. there are others that will effect the trim, but not in a negative way.
ALTHOUGH you should get some kind of tune with EVERY intake.
I said INTAKE and NOT drop-in filter. Intake means open cone filter with some sort of adapter.
I repeat you do NOT need a tune with the Injen. It does not screw your fuel trims like other intakes. If your fuel trims go positive, as they do with all the other intkaes listed in this thread, then the car will run rich at WOT. With the Injen, the trims are contianed at +5 to 7% positive. So the car does not run rich.
Please read the link that I provided, this way you understand what I am saying before you post.
Old Nov 6, 2010 | 08:37 PM
  #77
Kracka's Avatar
Originally Posted by nj1266
Every intake that was mentioned by the OP disturbes the fuel trims EXCEPT the INJEN. It is the best intake for the Evo 10. It is the ONLY intake that you can install without a tune. All others require a tune to correct the screwed up trims that the intake causes.
So much false here it makes me sick.
Old Nov 6, 2010 | 09:16 PM
  #78
nj1266's Avatar
My data is in the link that I posted, go read it. I stand by what I said: The Injen intake does NOT screw the fuel trims. That is why you do not need to tune for it. All others screw the trims to 10% to 12.5% positive. That causes your car to run rich and it might trigger a CEL. It is all about positioning the Hot wire MAF correctly. You will note that all the intakes that skew trims positive have the MAF very close to the cone, The Injen does not. The size of the pipe also matters. Injen got the pipe sizing and the MAF placement correct.
Please go read the link that I posted. What you said does not stand up to the facts.
Old Nov 7, 2010 | 02:57 AM
  #79
oftheheavens's Avatar
ok you are right and everyone else is wrong...
richardjh
120
Oct 6, 2017 08:58 AM
Liquid0401
For Sale - Cars For Sale
14
Apr 15, 2016 12:27 PM
korizmo
Nov 4, 2012 05:19 PM
GregGSC
Dec 8, 2009 09:18 PM
Richard EVO
31
Feb 6, 2009 06:48 PM
