Sponsored by:
Sponsored by: CARiD
AC is hissing
Old Aug 30, 2010 | 12:45 PM
vassili's Avatar
AC is hissing
ok, wtf...the ac is hissing at me on the hottest day of the year! still have cold air on driver vents but both passenger vents are blowing hot air...
i've had the car (08 MR) since last MAY. this should still be covered right? just want to make sure because dealer might pull a fast one.
Old Aug 30, 2010 | 03:45 PM
sideway180sx's Avatar
if they don't find any leaks or anything wrong they will charge you for an a/c service, thats how the mitsubishi over here do it.
Old Aug 30, 2010 | 07:28 PM
irmerm's Avatar
probably a loose vacuum line on one of the actuators inside the dash (if they use vacuum actuators that is). May just have to pull the dash apart and find the source. makes for a fun weekend.
Old Aug 31, 2010 | 10:27 AM
vassili's Avatar
they won't blame this on me installing a double din navi a few months ago will they?
Old Sep 1, 2010 | 05:16 PM
iceman1680's Avatar
I'd bet my Evo they will.
Old Sep 2, 2010 | 07:33 AM
wild01ride's Avatar
^ LOL!
Yeah, there aren't any vacuum actuators (that's old-school!).
Weird though that the air would blow cold out one side and not out the other.
Are you sure that you let it run long enough before comparing the sides? If the car's been sitting in the sun, the heat soak could make the air blow hot for a long time before cooling down.
Good luck and let us know if you figure anything out - I'm sure it would be good for all of us to be aware of.
Old Sep 2, 2010 | 08:52 AM
vassili's Avatar
took it to the dealer and they tried to pull codes and checked the compressor clutch...nothing. now i have to go to a different dealer since the one i went to didn't have an actual "AC machine" to check for leaks and such. PITA! at least they didn't charge me.
Old Sep 22, 2010 | 08:19 PM
irmerm's Avatar
updates?
Old Sep 22, 2010 | 08:47 PM
evo8 951's Avatar
Maybe a snake? Kidding Kidding. lol
Old Sep 22, 2010 | 09:13 PM
racingguy13's Avatar
I will guarantee that the system is just low on charge. I have seen this a lot when the system gets less than half and usually less than a quarter charge, it will still put out cool air our of certain vents and will make a hissing noise because there isn't as sufficient charge for the system so it's almost running on fumes. There doesn't necessarily have to be a leak for this to happen, closed systems still lose little by little and it's possible that it came undercharged from the factory. I've done numerous recharges and found low systems on practically new cars with no leaks found. Unfortunately it won't be covered (only under 12 month/12,000 miles) unless they find an actual leak. If it's just a recharge they will most likely charge you.
daleeusebio
Outlander Sport
Aug 31, 2015 08:31 AM
blurr001
May 8, 2014 10:50 AM
Lumpy
Lancer Troubleshooting
Sep 2, 2010 08:34 AM
mitsubsushi
Toronto Lancer Club
Jun 3, 2010 01:55 PM
initialDRacer
15
Sep 11, 2007 08:12 AM
