Sponsored by:
Sponsored by: CARiD
Tread on only ONE tire gone??
Old Sep 7, 2010 | 07:27 PM
got_em's Avatar
Ok, so I noticed the other day that three of my tires have about 85% tread life on them except for one, the rear right tire needs to be changed ASAP, about 10% life left........ This is about 2 weeks after my low tire pressure light went on, i checked the tires and they were at 25psi (yea I let time get away from me). Now i don't remember but that rear right tire might have been even under 25psi, I did not check the tread on the tires. Though it is likely that that tire might have been under inflated and that caused the tire to be ruined, What other things might have caused that one rear right tire to be the only one with no tread?
Old Sep 7, 2010 | 07:38 PM
Tuxevo's Avatar
Alignment. Hit and curbs or holes lately?
Old Sep 7, 2010 | 07:47 PM
got_em's Avatar
I mean, I actually drive the car, so yea, being in Chicago often, the car has seen its share of potholes and curbs now that I think of it. Guess I should go to an alignment shop to get it checked out.
Old Sep 7, 2010 | 08:20 PM
Mike Bones's Avatar
Same here. Same wheel. Same problem. The finance manager told me to pick up the "wheel and tire" package, which I did reluctantly. I curb rashed that particular wheel 6 months ago and every 3 days the tpms light comes on. Call me lazy, but I had a kid and things got hectic around the house so I haven't had a chance to bring the car in to have the wheel replaced. I have to do it soon because winter is around the corner and I'm sure it will get worse.
Old Sep 7, 2010 | 08:25 PM
ugakirk's Avatar
+1 on alignment.
Old Sep 7, 2010 | 09:15 PM
dreamerak's Avatar
make sure you put on four new tires
Old Sep 8, 2010 | 10:45 PM
got_em's Avatar
The thing is, I just bought the tires.......... I was going to replace just the tires in the rear with the same tire. I dropped a decent chunk of money into these and cant really afford both front and back.
Old Sep 8, 2010 | 11:31 PM
dreamerak's Avatar
If their that new then you could just replace the one tire as long as it's the exact same tire, check your tread depth on your existing tires vs. the new one. the thing is if the difference is too great you could damage the AWD system and that would be big $$$$. Remember the size tolerance is front to back as well as side to side.
Old Sep 9, 2010 | 06:43 AM
ugakirk's Avatar
remember the size tolerance is front to back as well as side to side.
+1
Old Sep 9, 2010 | 02:11 PM
got_em's Avatar
If their that new then you could just replace the one tire as long as it's the exact same tire, check your tread depth on your existing tires vs. the new one. the thing is if the difference is to great you could damage the AWD system and that would be big $$$$. Remember the size tolerance is front to back as well as side to side.
U scared the hell out of me, THANKS!!!!!!!!!!!! Now I'm worried!. Guess that's another few grand gone...
Thanks for letting me know tho. I was about to just switch the tires to make sure it wasnt just flat on air, guess its time to go to the shop.
Old Sep 9, 2010 | 04:44 PM
ptakats's Avatar
see i had the same issue and i checked the alignment on a rack and made sure it was fine after i got hit and for some reason that 1 tire went damn near bald in no time at all. The only reason i really noticed was when i did a tire rotation it was so low, so it might actually be the front passenger side that has the issue. What could have caused it if pressure and alignment with an empty car is all ok?
Old Sep 9, 2010 | 05:38 PM
jgray2010's Avatar
good luck on getting it fixed no matter what the problem is
Old Sep 10, 2010 | 04:58 PM
Johnr352's Avatar
where is the wear? On the inside or outside edge? If so, I bet you toe is off.
Old Sep 10, 2010 | 08:46 PM
►EvolutionX◄'s Avatar
Oh no , wheres your toe gone to? Haha. Alignment doesn't normally just go out on one side of the vehicle without causing a pull (unless its in the rear, in which case yours is) Get the alignment checked and do regular tire rotations.
Old Sep 11, 2010 | 04:03 AM
Johnr352's Avatar
It does if you hit something... or it has for me. Hit a little curbing on the track and knocked my toe silly on my right front. Burned up the tire something awful, whereas the others were just fine...
russ72
Dec 26, 2015 10:08 PM
evremonde
10
Aug 26, 2015 01:44 PM
Anarchy08
10
Oct 22, 2010 02:12 PM
Rcebowl
24
Jun 20, 2007 03:32 PM
mitsugsx
Apr 20, 2007 02:52 AM
