Sponsored by:
Sponsored by: CARiD
Does your X burn oil??
Old Sep 8, 2010 | 05:35 PM
kirkklau's Avatar
are Xs tend to burn oil and have to put in engine oil often?
How often should we have to check?
Does the check engine light come on if the engine oil is low?
thanks guys.
Old Sep 8, 2010 | 09:04 PM
AFD's Avatar
AFD
Mine hasn't between 3k mile changes.. at least not an amount that I can tell, if it does.
Think the owner's manual says you should check fluid levels and tire pressure every time you fill the gas tank.
Not sure, but I'm guessing it doesn't if the oil level is low, but still within the maximum and minimum range. The check engine light will probably come on when your oil is really low and other things start breaking, lol.
Old Sep 8, 2010 | 09:19 PM
heavyD's Avatar
I've never added a drop of oil between changes.
Old Sep 8, 2010 | 10:16 PM
mlomker's Avatar
If your motor nor head has been built then your turbo is probably burning oil. Valve seals, piston rings, and turbo are the three main possibilities.
Mine burns some oil so I'm going to have the turbo pulled this Winter to have the seals inspected.
Old Sep 9, 2010 | 07:33 AM
tim788's Avatar
mine does not burn a drop...im completely stock and i have gone as far as 4500 miles between oil changes.
Old Sep 9, 2010 | 07:36 AM
ugakirk's Avatar
Dang. 4500? I usually change mine around 2000-2500
Old Sep 9, 2010 | 07:45 AM
Webman's Avatar
Just changed my oil a week ago. About 5500 miles on it, and there wasn't a drop missing, before I drained it.
Old Sep 9, 2010 | 07:46 AM
derekste's Avatar
7500 mile drain intervals here, don't lose a drop.
Old Sep 9, 2010 | 08:27 AM
SIS3ON's Avatar
not a drop during 3k change intervals. I don't baby my Evo either – once I see it's safe to do so, I'll let her loose.
Old Sep 9, 2010 | 08:46 AM
wiretap's Avatar
I do 5000 mile intervals. Never need to add any.
Old Sep 9, 2010 | 08:51 AM
Mr. Move's Avatar
Yea 3k changes here not a drop missing.
Old Sep 9, 2010 | 08:57 AM
scarryy's Avatar
Ditto that. 45000 miles around 5000 mile changes, never low.
Old Sep 9, 2010 | 10:13 AM
sgounaro's Avatar
No loss of oil here. Oil changes every 3k.
Old Sep 9, 2010 | 10:19 AM
evolution2186's Avatar
If you're changing your oil prior to 3k miles while not making your engine sweat (RACING) you're changing prematurely. I change my oil at 4k miles even with E85! Oil checks out great even at 4k!
Old Sep 10, 2010 | 04:56 PM
JimGVT's Avatar
No oil burning. I have had slight issues with oil seeping around the drain plug even with replacing the crush washer with each change. Just enough to get the undercover dirty. I think I'll try nylon instead of metal washer next time.
