Sponsored by:
Sponsored by: CARiD
my Evo X won't start!
Old Sep 14, 2010 | 12:56 PM
ice1874193's Avatar
bought my car new in dec '08 and it has done that probably 5 times or so. i think usually when it was cold out. car was 100% stock
Old Sep 15, 2010 | 12:44 PM
derekste's Avatar
go to the dealer with these symptoms. they will give you the relay(s).
even if it isn't the relay, you want the relay anyways, and more-so you want to eliminate it as causal factor.
Old Sep 15, 2010 | 01:14 PM
Noize's Avatar
EvoM Administrator
Is it usually warm start when it does this?
Old Sep 15, 2010 | 04:34 PM
derekste's Avatar
tsb says cold I believe
Old Sep 15, 2010 | 07:19 PM
Noize's Avatar
EvoM Administrator
My first X did this when it was a warm start, probably about once a month. It didn't matter if it was hot or cold outside. From a cold start, though, it never did it.
Old Sep 15, 2010 | 07:50 PM
lancerarmstrong's Avatar
my 2010 MR has done this once but I knew it probably would have done that. i was trying to instigate the problem and it happend the first try... basically you can't get in and start it immediately, i found that if you just let it sit in accessory for a few seconds and then crank it that it runs perfectly after that. could be that pump relay everyone is talking about?
i gaurantee you it's not the battery from the symptoms you are having
Old Sep 16, 2010 | 04:02 PM
JimGVT's Avatar
I've also had this happen 5 or 6 times in the 18 months that I've owned the car, but haven't been able to correlate to anything (hot, cold, warm start, etc). Has happened before and after updated relays. In all cases, I shut if off, waited ~30 sec and then it started the next time but had to give it gas once or twice before it started idling correctly. I've decided to ignore it unless it gets more frequent.
Old Sep 16, 2010 | 05:16 PM
mlomker's Avatar
I had this all the time on the stock tune. I got tuned and it all went away. If your car is totally stock then have your dealer check if you have the latest ROM.
Old Sep 17, 2010 | 01:45 PM
Evo@95670's Avatar
Could be battery or just a bad relay. How long does it sit? or is it a DD?
Old Sep 17, 2010 | 05:49 PM
Darwinism's Avatar
Is your car equipped with the FAST key system? I've had a few X's come into the shop with the same problem, some won't even start the car at all. There is a TSB out to replace both keys and program them to the car. It seems to be a common problem on earlier X's. Hopes this helps.
jerrymldz
Jun 16, 2017 02:40 PM
Wmu240
Dec 18, 2015 10:18 AM
OPENA(671)
Aug 12, 2013 11:36 PM
Peter Gallup
14
Aug 13, 2012 03:09 PM
khmerguyx
Dec 30, 2011 12:03 AM
