Sponsored by:
Sponsored by: CARiD
08 Evo X GSR retrofit help
Old Oct 13, 2010 | 11:02 AM
samsam12341's Avatar
Hello everyone, I've always been lurking on here but never posted before but now I need some help. I've finally decided to commit to doing a projector retrofit for my evo x since its depressing to turn on my dinky halogen lights.
I am going to purchase a set of headlights, TSX projectors, HID kit, and some other stuff. My main question is about the shrouds and fitting. I consider myself pretty good with a dremel so I think I can custom fit anything but I want to get some second opinons on what to do.
If I decide to go ahead and get a pair of the E46 shrouds, I am curious on how they will fit and look in the housing because I don't think they are full circle and I don't really want the projector to be exposed. Will these also fit with the tsx projectors? I think e46 shrouds are 3" and the tsx projectors are 2.5 (lemme know if im wrong). Someone experienced please feel free to help
Thanks guys!
Old Oct 13, 2010 | 11:35 AM
iEvoVII's Avatar
Personally,
SSS HL vs Non-SSS HL with E46 shrouds + TSX projectors = SSS HL wins asthetically. Looks so much better
However,
SSS HL vs Non-SSS HL with TSX projectors = Non-SSS / TSX light output.. TSX low beam is wider / more intense than SSS low beam
At the end of the, both projectors do a good enough job at lighting the road at night but you cant beat the look of a SSS HL...
Pix of custom Non-SSS HLs courtesy of Lightwerkz:
http://www.lightwerkz.net/gallery/ma...g2_itemId=3856
There are 2 versions of the Replica E46 shroud:
* Normal &
* Extended (full circle)
If you look closely at some of the Lightwerkz HLs youll see both versions have been used..
Good luck
Old Oct 13, 2010 | 11:37 AM
thanks for the reply, could you descripe what the SSS? Is that the stock projector headlights?
Old Oct 13, 2010 | 11:52 AM
iEvoVII's Avatar
^^ Yep.... OEM MR HLs
Old Dec 7, 2010 | 12:37 AM
Ok guys, little update on my status, I ordered an extra set of headlights and the projectors and I recieved the projectors today. However, they are not TSX projectors, they appear to be FX-R replica projectors and I was wondering on your guys imput on them. How do they compare to TSX? Does the fact that its a replica mean they won't be as good as oem FX-35 projectors? Also, they seem to be slightly bigger than TSX projectors and I was wondering if they would fit my headlights. I dont have my pair in yet so I'm going to the pro's here to see what you guys think. Heres a picture of them:
Old Dec 8, 2010 | 09:52 AM
bump comn people someone has to know something!
Old Dec 8, 2010 | 10:04 AM
boondoc's Avatar
im also looking into retrofits for my RA and i was told that as long as its not bigger than 3" you should be fine without much modification. 2.5" is ideal though, i beleive the FX is 3".
Old Dec 10, 2010 | 07:26 AM
bakerunc22's Avatar
This might be something that your interested in:
https://www.evolutionm.net/forums/ev...ts-making.html
tsitalon1
28
May 4, 2015 12:42 PM
andrey_rinta
Evo X How Tos / Installations
Apr 13, 2014 11:57 AM
jpsEVO
Oct 26, 2013 12:49 PM
cbrkp
Canadian Forum
Nov 4, 2009 08:46 PM
vonzipper
13
Dec 13, 2007 12:24 PM
