Sponsored by:
Sponsored by: CARiD
Should i get a DP or FMIC?
Old Oct 26, 2010 | 01:11 PM
  #31
ETS Michael's Avatar
Go with the front mount, no need for a tune. The front mount will actually provide more gains then the down pipe on the stock turbocharger.
Check out this link for our dyno results with no tuning and just bolt on parts.
https://www.evolutionm.net/forums/ev...ts-thread.html
It's a good read
Michael
Old Oct 26, 2010 | 01:17 PM
  #32
m3bmw99's Avatar
+1 , fmic
Old Oct 26, 2010 | 09:51 PM
  #33
tlsole's Avatar
Thanks for the info guys! I will be piecing my I/C setup starting off with the Cobb uicp/hardpipe (found a used set for a decent price). Anyone know anything about the Cobb UICP? I know they are currently remaking it, but have no clue why..
Old Oct 27, 2010 | 05:38 AM
  #34
HiI'mDustin's Avatar
a metal pipe is a metal pipe. As long as it dosent rust you are fine. We welded mine cuz im super cheap haha
Old Oct 27, 2010 | 08:48 AM
  #35
tlsole's Avatar
Yeah i know a pipe is a pipe, i just like the look and i kinda wanted something to accent the blue cobb inlet i have since it looks werid being the only blue under the hood..whats better than a cobb uicp/hardpipe to do the job haha
Old Oct 27, 2010 | 01:01 PM
  #36
MDH-005's Avatar
Originally Posted by trb0sdn
3) DP: increases volumetric area for exhaust gases to escape. Likely improves flow, increasing engine efficiency (see a trend?)
This is a mistake that many people make.... some of the wide mouth DPs are in fact worse for flow as they cause a turbulent condition.
The rally teams have a more scientific approach. See attached.
http://www.alhabtoor-motors.com/rall...T9A%20CZ4A.pdf
you will have to excuse the lack of technical language......
Old Oct 27, 2010 | 01:05 PM
  #37
Kracka's Avatar
It's a good part. They redesigned their LICP to fit both the GSR and MR. The UICP stayed the same, but they did have supply issues with their bender and coater for a bit, but that should all be sorted out now.
Old Nov 1, 2010 | 12:04 AM
  #38
tlsole's Avatar
Just installed the pipe this weekend but its the older version and i like it. I like the gunmetal color with the blue couplers.. plus the hardpipe/uicp look good together.
BTW, anyone know Cobbs email? Tried calling them so i can find out if i can purchase a rubber coupler, my dog chewed up one for the UICP and the stock ones slightly small.
Old Nov 1, 2010 | 11:20 AM
  #39
OBP's Avatar
OBP
sales@cobbtuning.com
Old Nov 1, 2010 | 01:35 PM
  #40
boostawd16's Avatar
fmic, a dp wont give you the gains like the front mount especially in the heat
Old Nov 1, 2010 | 01:45 PM
  #41
MicRX's Avatar
+1 for the fmic, if you can just go with a true tbe, no fit issues and alot of big named companies do alot of research and have good dyno results that you can use to guestimate your overall horsepower if you don't have access to a dyno.
Look in the part out section if money is an issue
Old Nov 2, 2010 | 03:16 PM
  #42
ClaudioEvoX's Avatar
go with the dp!!!!!
Old Nov 6, 2010 | 09:46 AM
  #43
fromWRXtoEVO's Avatar
Downpipe.
Carlos
Old Nov 6, 2010 | 10:04 AM
  #44
dericchan1's Avatar
Eventually you will need both, as FMIC does make a difference and will improve performance down the road but at the moment I would suggest you go with a DP first
Old Nov 6, 2010 | 10:15 AM
  #45
Robevo RS's Avatar
i would get a O2 housing with a downpipe or a combo, since it is not as easy set up as the 4G63T was , why you pay double amount of money for install? If you dont get a combo , i got a Megan O2 housing for cheap around $160 as an option for you. So its a worthy update on your idea to think about the combo or an extra parts which would be costly later to install.
Rob
