Sponsored by:
Sponsored by: CARiD
I'm not all that worried, but SHOULD I BE?
Old Dec 15, 2010 | 02:49 AM
EVO X 6950's Avatar
Originally Posted by deanob
id invest a cel reader/clearer. I randomly toss o2 trim level / low circuit all the time. Sometimes 1 or twice a month and sometimes 0 for months at a time...
I find these ecu's are quiet picky.
+1
Old Dec 15, 2010 | 02:50 AM
EVO X 6950's Avatar
Originally Posted by hibby
Bought a OBDII reader. I figure it'll save me some effort in the long run, and it wasn't that expensive. Will share more info once it arrives.
I got mine from pep boys for like $50, the best cheap investment
Old Dec 15, 2010 | 04:48 AM
journeymansteve's Avatar
My last overboost (MAF reading out of range, or something like that) hid itself on the SES on dash, but the OBDII puller found it. Had to go from the 'Zone to O'Reilly to clear it because a pinhead biatch at 'Zone wouldn't let me. (How screwed up is that?!)
I wish we had pep boys 'round these parts. OBDIIs around our parts stores are ~$150 to have one that can clear codes.
Old Dec 15, 2010 | 06:23 PM
AWDJUNKi's Avatar
Originally Posted by racingguy13
You can't just cycle the key to get the check engine light to go off. Most faults need two drive cycles with no fault for it to go off, if it's a fault that will go off itself. You have to have the car running for the tests to activate, and then also be under certain conditions for some to run. Just get it checked, or find someone with an AP or go to an AutoZone or something to see what the code was.
almost sure the ap with the evo works just like the one on my subaru.. it should marry to the car, which most people aren't gonna go through the hassal to cause it would prolly take an hr to de-marry your car marry to there's clear a code then de-marry and marry again to your car, id been at ad. auto parts bought a scanner cleared the code and at my local bar having a by the time yall finished playing with each other sorry just saying
Old Dec 15, 2010 | 07:16 PM
racingguy13's Avatar
Yeah forgot about that. I have one connected to my car and still didn't register. I come from VW/Audi land where people have VAGCOM and can do everything the OEM scan tool can do and that's where my mind was.
Old Dec 15, 2010 | 07:25 PM
Crester's Avatar
That's the best thing to do. Even if it turns out to be no big deal... at least you'll know that for sure. And you'll be able to use it on your car and friends cars in the future.
Old Dec 15, 2010 | 11:05 PM
hibby's Avatar
Right on. I actually popped for a pretty nice one from Innova that had good ratings on Amazon. I figure this is one of those purchases I'll only need to make once, so I spent a little more.
Old Dec 15, 2010 | 11:30 PM
SniperwolF's Avatar
keep us posted ...
Old Dec 17, 2010 | 10:22 PM
hibby's Avatar
P1235
Per the scanner's freeze-frame 5500ish RPM, speed to remain undisclosed but >65, TPS somewhere near WOT but not 100%, ambient temp 17 degrees.
From what I've read so far, no cause for alarm...
Old Dec 19, 2010 | 06:42 AM
P1235
My favorite SES. "Overboostin'" Now when others say you're not driving your car hard enough, tell them you overboost and have a SES to prove it.
P0171 is the other bad MAF one; that says system 1 bank too lean. In that case, CLEAN your Maf.
Yep, picky and sensitive ECUs.
lghtngyello03
May 1, 2020 01:15 AM
06LancerRA
Jan 7, 2015 10:52 PM
xceler8rob
Sep 1, 2009 09:12 PM
beatnik
Lancer Troubleshooting
Nov 13, 2002 10:38 PM
