Sponsored by:
Sponsored by: CARiD
P0031 (o2 sensor low voltage)
Old Feb 8, 2011 | 03:19 AM
eboru-shon_x's Avatar
Hi Everyone. The other day my x through an SES and looked underneath the car; found out the harness to the NB o2 sensor had torn apart. Now it looks like I need to buy a new o2 sensor; the questions are:
1) Are o2 sensors universal? From what I'm reading, o2 sensors from the dealership/factory cost over 300 dollars.
2) Do any of you have aftermarket Narrowband o2 sensors, that you could link me to. I've looked online but couldn't find one that was compatible with the evo x.
3) Dangerous to drive a while under this condition? I can ignore the SES but will it have any short term / long term effects.
Many thanks.
Old Feb 8, 2011 | 05:46 AM
Crester's Avatar
The cheapest sensors are universal ones. This doesn't necessarily mean "no-name brand"... it just means they don't come cut to length... so you'll need to install and cut the wire as required and then splice on a connector. It's a good way to save a good amount of money... and on my last car it was no problem to splice the wires. We just heat shrank the wire splice... and even tho the splice was located under the car... nothing happened even tho I drove it thru salty winters.
Old Feb 8, 2011 | 06:01 AM
thanks. what about something like this?
http://www.amazon.com/Denso-234-4622.../dp/B000C5SGA4
do you have a product link to the o2 sensor that you replaced the stocker with? many thanks
Old Feb 8, 2011 | 06:15 AM
Crester's Avatar
I didn't replace any O2 sensors on my EVO yet. I replaced them on a Lexus I had previously. My mechanic apparently had Denso sensors with long wires and no connector. So we had to re-use my old connector. The universal DENSO sensor saved me a lot of $$$!
Old Feb 8, 2011 | 06:22 AM
iowa_guy's Avatar
Remember you cant really splice the connection as any unwanted resistance *could* throw off the readings. Sounds like your on the right track with wanting a total replacement unit
Old Feb 8, 2011 | 06:52 AM
i did a search on what o2 sensors are compatible with the x and this one came up.
http://www.amazon.com/AC-Delco-213-1...2008&carId=001
does anybody know about anything this specific sensor? thanks
Old Feb 8, 2011 | 07:03 AM
or, can the rear o2 sensor be used on the front? i have the rear sensor replaced with an aftermarket wideband. any thoughts? thanks
Old Feb 8, 2011 | 06:44 PM
bump
Old Feb 8, 2011 | 08:32 PM
Crester's Avatar
Why can't you splice an O2 sensor wire? How else would you make use of universal length O2 sensors that come from major brands like DENSO?
Old Feb 8, 2011 | 10:04 PM
i agree. but is there a reason why you didn't just splice the wires back up? or did the sensor itself go bad in your case. thanks
tunermt
Cobb AccessPORT
20
Jul 30, 2020 10:38 PM
kingRob757
Mar 16, 2016 08:17 AM
max4rw
Feb 12, 2016 04:04 PM
thedeatons
Lancer Troubleshooting
19
Jan 29, 2009 11:41 AM
vegasevo9
20
Nov 19, 2008 09:59 PM
