Sponsored by:
Sponsored by: CARiD
Evo X Bogs at 4000rpm?
Old Apr 10, 2011 | 04:59 PM
ptakats's Avatar
This is a new development. 2010 Evo x GSR just under 30k miles daily driver. While driving on the highway (tested this with all gears) if Im at steady speed in either 3 4 or 5 gear ad ~3500rpm and I floor it the rev jumps like its building pressure, drops 500 revs then continues to build up. Clutch isn't slipping, plugs are good, and hoses aren't leaking. I cant figure it out. I did have a cobb tune on it for 9 months now and de-tuned it to stock and the issue didn't go away. Has anyone had this issue before?
Old Apr 10, 2011 | 05:01 PM
dcpatters's Avatar
Mods on car? Are you the original owner? Have you tried logging with the AP to see what was going on?
Could be a myriad on things but too little detail to comment.
Old Apr 10, 2011 | 05:03 PM
Subi.convert's Avatar
have you checked the vacuum line everyone warns about?
Old Apr 11, 2011 | 01:42 AM
ptakats's Avatar
the only mod are the tune, k&n filter wheels and an hks turbo timer. i am the original owner and i checked the hoses and they were connected firmly but i cant check for a crack in the hoses
Old Apr 11, 2011 | 05:26 AM
oftheheavens's Avatar
go to autozone and get new hoses if you even think there could be a crack. they are cheap, and better quality.
Old Apr 11, 2011 | 10:45 PM
dcpatters's Avatar
Fuel pump relay?
Old Apr 12, 2011 | 11:52 AM
ptakats's Avatar
turns out its my clutch heating up and loosing grip sad thing is its getting worse every single day so it really must be on its last legs
Old Apr 12, 2011 | 01:08 PM
dcpatters's Avatar
Initially I would have guessed clutch but you said it was ok. Nevertheless, 30k for a stock clutch is not too bad.
Old Apr 12, 2011 | 04:13 PM
ugakirk's Avatar
I was about to say clutch too the way you described it. I would baby the car and try to find a shop ASAP. The longest it'll last is a few weeks if its a daily.
I'm about to hit 30k and I had to go up an big incline of about 70 degrees from a stand still so had to slip the clutch a good bit. It was seriously felt like going straight up. I'm kinda worried about mine now. It seems the engage point higher although I did a couple pulls and it seems really good.
Old Apr 13, 2011 | 10:14 AM
ptakats's Avatar
well just so you know i didnt baby mine at all i kicked its *** so dont think that 30k is the average life expectancy of these things i live in southern california hitting the canyons on the weekends and i drove across the country
Old Apr 13, 2011 | 12:44 PM
Sly Moose's Avatar
Has the car been reflashed from the dealer? Theres and update...
Old Apr 14, 2011 | 02:04 AM
ptakats's Avatar
no it hasnt
03OZstocker
Lancer Engine Management / Tuning Forums
Mar 30, 2017 10:27 PM
lathiat
Sep 1, 2015 09:58 PM
Evorange
Feb 11, 2013 04:33 AM
211Ratsbud
Nov 27, 2012 08:06 AM
