Sponsored by:
Sponsored by: CARiD
Adjust HID headlights for SSS package?
Old Apr 12, 2011 | 11:15 AM
angdefeo's Avatar
Can the angle of the headlights for an '10 EVO X with the SSS Package be adjusted?
I have the dial set to (0) the lowest setting and when the lights are on at night, they still point to low. Is there something that can be done to raise the angle of the projection? If so has anyone done it and what do i need to do to make this adjustment?
Old Apr 14, 2011 | 08:59 AM
KSIceman's Avatar
I'm pretty sure that's the point-- you're not supposed to blind other drivers. If you need more light, you're probably in a more rural area without streetlights in which chase there would be an opportunity to flip your high beams on.
If you're not satisfied, however, check the top/back of your headlight housing under the hood for a ratcheting type adjustment. That's where they typically are on most cars.
Old Apr 14, 2011 | 11:52 AM
sfearl1's Avatar
um, correct me if i'm wrong, but doesn't 0 mean the lowest setting? wouldn't you want to flip it up to like, say 2-3?? i keep mine in the middle on either 2 or 3 and it's fine.
Old Apr 14, 2011 | 12:04 PM
NJ Drive's Avatar
This took less than 15 seconds to find.
https://www.evolutionm.net/forums/6373768-post12.html
Old Apr 14, 2011 | 12:20 PM
dyss.'s Avatar
i bet the owners manual has it too
Old Apr 14, 2011 | 12:49 PM
angdefeo's Avatar
When I have the dial on 0 the lights point to the highest point. When I put it on 2 or 3 they point lower.
I had that diagram when I tried the first time to make the adjustment. The location of the adjusting bolt/screw is now clear.
Checked in there first and there was nothing about adjusting the lights.
Old Apr 15, 2011 | 09:23 AM
menasor's Avatar
0 is the highest setting. You can't make them any higher. I have them set at 0 on my 2011 MR and it seems fine to me.
Old Apr 15, 2011 | 10:51 AM
linjy2's Avatar
my buddy adjusted my SSS package headlights. Now I can practically blind people if i put it on the highest setting. =D
Old Apr 15, 2011 | 11:10 AM
bluepeartype-s's Avatar
Registered User
2-3 is about the normal for most.. (off the topic) only thing I don't get is that angled HID's beam...why not straight?
Old Apr 15, 2011 | 11:17 AM
Kracka's Avatar
Lower on driver's side to prevent blinding oncoming traffic.
m0nkie
Dec 23, 2019 08:27 PM
Rookie05r1
Nov 15, 2015 09:23 AM
21Evo-lution
Nov 9, 2010 03:38 PM
jimm
Jan 30, 2010 01:32 PM
rageagtm
21
Mar 19, 2009 01:09 AM
