Sponsored by:
Sponsored by: CARiD
Headlights uneven
Old Sep 16, 2008 | 12:04 AM
m0nkie's Avatar
Headlights uneven
Hi, just picked up the EVO last Friday. Everything seems great, but somehow at night, the headlight seems to shoot out uneven distance. The left side beam seems a little closer compare to the right. When looking at the floor, it's very noticeable that there is a ~2ft distance.
here's a ****ty picture I drew to show it Does anyone else experience this problem? I tried adjusting the height (the dial) a few times but it still comes out like this. Should I take it back to the dealer to get it done or is there something I can do myself?
anyways, here's the my EVO. GSR with SSS package, 33,000 OTD
Old Sep 16, 2008 | 12:21 AM
ScottSpeed21's Avatar
They're supposed to be like that. The cut-off shield inside the projector is shaped with a step in it so that they light up the signs on the right side of the road, but don't blind other drivers coming toward you on the left. Pull up close to a wall at night with the headlights on and you'll see what I mean.
They're also Bi-Xenon projectors, which means when you hit the high beam switch, a solenoid pulls the cut-off shield away and you get a full HID high beam out of the same projector
Here you can see the step in the cut-off line. The projectors on the Evo have a little taller step on the right side.
Old Sep 16, 2008 | 05:10 AM
switchblade906's Avatar
oh i wondered why it was like that.
Old Sep 16, 2008 | 06:04 AM
JuancaROD's Avatar
AFAIK that's normal, it's designed that way so you don't blind incoming cars.
Old Sep 16, 2008 | 07:13 AM
Rguy's Avatar
Perfectly normal.
Old Sep 16, 2008 | 07:40 AM
m0nkie's Avatar
Thanks guys for the help
Old Sep 16, 2008 | 05:58 PM
Evostare's Avatar
learn something new everyday
Old Sep 16, 2008 | 06:21 PM
Papi4baby's Avatar
Wow i was going to go ***** at the dealer about it, good post.
Old Sep 16, 2008 | 06:47 PM
JoeyM3's Avatar
my drivers side is noticeably lower, and there is no way to adjust it
Old Sep 16, 2008 | 08:25 PM
hel_if_ino's Avatar
Yes... the way it's supposed to be.
Old Sep 17, 2008 | 06:49 PM
m0nkie's Avatar
lol I was about to do the same...
Old Sep 17, 2008 | 08:16 PM
JoeyM3's Avatar
i meant passenger side
Old Sep 17, 2008 | 08:45 PM
Q15H's Avatar
There is an individual height adjustment for each reflector but I don't see an adjustment for left-to-right setting on either headlamp assy. Will have to take off the front bumper cover and investigate
Old Sep 22, 2008 | 09:50 PM
JoeyM3's Avatar
just used the attached file to find the adjustment. rather than using a screwdriver i just used a 5mm socket to adjust the nut. ill have to drive the car tomorrow and see if any further adjustment is needed. thanks for the info
Old Sep 23, 2008 | 05:32 AM
is300's Avatar
good info
