Sponsored by:
Sponsored by: CARiD
New Intercooler question.
Old Apr 17, 2011 | 06:24 PM
Bizzlex's Avatar
I just got a Turbo XS Intercooler, UICP and LICP and my car now sounds like it is a giant high pitched vacume cleaner when i get on it. Is this normal???
Thanks
Old Apr 17, 2011 | 06:34 PM
EvoX-11's Avatar
boost leak...
Old Apr 17, 2011 | 07:01 PM
Bizzlex's Avatar
They said it was normal, how do i find out for sure if its a leak and how do i target it?
Old Apr 17, 2011 | 07:03 PM
SimX33's Avatar
Listen for it, then lil soap and water...watch for bubbles
Old Apr 17, 2011 | 07:05 PM
Bizzlex's Avatar
while the car is idling? The custom shop told me that the sound is from the air moving through the pipes, not leaking out lol
Old Apr 17, 2011 | 07:14 PM
techmaster's Avatar
A good idea would be a boost gauge so you can actually have numerical data for before/after installations. One look at it during a pull, and you know if you are leaking or not.
Old Apr 17, 2011 | 07:51 PM
GTbullet's Avatar
re tighten all of your clamps. i had a similar issue with my ETS and it turned out to be a loose clamp.
Old Apr 17, 2011 | 08:03 PM
Evoardo IX's Avatar
search the forums for a proper way to do a boost leak test, I had some major leaks when I installed my IC and pipes, had everything fixed after a boost leak test.
Old Apr 18, 2011 | 08:54 AM
Bizzlex's Avatar
Thank you all for your help, i found it GT bullet was spot on.
Old Apr 18, 2011 | 09:26 AM
Pawkingss's Avatar
"air moving thru the pipes" typical idiot mechanic speak. what a joke.
Old Apr 18, 2011 | 10:49 AM
SimX33's Avatar
Nice. Enjoy the new IC
Old Apr 18, 2011 | 05:18 PM
tico915007's Avatar
I would never take my car back there again I would be insulted if someone told me that they either don't know what they are doing or are to lazy to check the pipes again
Old Apr 18, 2011 | 05:43 PM
Bizzlex's Avatar
they do know what they are doing, when i took it back i talked to the manager and their fabricator. both who know what they are doing, the fabricator created a nozzle to pressureize the system to find the leak.
Old Apr 19, 2011 | 05:44 AM
GTbullet's Avatar
That's what we're here for.....for others to learn from our mistakes. Good luck, and enjoy the new power with responsibility
Old Apr 19, 2011 | 02:52 PM
Wrex1977's Avatar
boost leak test. I have 2 different sizes from testing my WRX. PVC caps with a hole drilled in. Insert a fitting and attach some hose. $4 to test for boost leaks.
