Sponsored by:
Sponsored by: CARiD
Agp cai?
Old Jun 22, 2011 | 12:24 AM
DBTurMOMtchzME's Avatar
Agp cai?
Ok guys I been looking for a true cold air intake and the agp incorporates this(i.e. sucks cold air from fender and not hot undens air from under the hood). Has anyone used this intake and do you need anything extra to make it work, does it go straight to the turbo or do you have to use factory turbo inlet? Thanks for you input.
Old Jun 22, 2011 | 07:30 AM
ravenjam's Avatar
The one I got I had issues with the opening for the MAF. I ended up blocking that hole and using my stock intake and MAF housing. Then attached that to the rest of the CAI pipe. Not the cleanest setup but it works.
Old Jun 22, 2011 | 09:48 AM
Jookies's Avatar
Just some advice, for T/C cars that have an I/C. The I/C is pretty much the "cold" part of your intake. You really dont need to go as far as CAI.
Old Jun 22, 2011 | 09:50 AM
Kracka's Avatar
Agreed, you're better off putting that extra money towards a nice intercooler.
Old Jun 22, 2011 | 10:27 AM
MRevolicious's Avatar
^^wise words from Roberto. plus you won't have to worry about running over large puddles of water and such. short ram is all you need.
Old Jun 22, 2011 | 03:09 PM
I have a ets 4" intercooler on the way along with a grocery list of parts. And yes a intercooler does pull cool air in but you still don't want hot undense air from The engine bay. You guys are sorta correct saying not to waste you money on a intak in some cases cause some of you guys get short ram or untrue cai and those don't really make a diifrense because they are pulling hot undens air from the engine bay where a cold air intake pulls cool air from out side of the car that is more dense and there for easy to tune the fueling and volts perfectly. See?
Old Jun 22, 2011 | 06:01 PM
Jookies's Avatar
They absolutely do make a difference, look at the stock panel air filter and how dense it's material is, and how small of a passage the air has to move from outside up to the filter. You are making the air flow much more freely which is paramount with a turbocharged car, because a good portion of our power rests on the turbo's ability to suck air in quickly and efficiently. Will a CAI pull colder air in? without a doubt, but if the air is going to be cooled the the correct temp within the intercooler, why spend the extra money?
And do me a favor and take a look at the design of the X's front end and hood vents, the amount of air put through that big front grille and shot out the vents cools the air off inside the engine bay very efficiently.
This is completely ignoring the fact that: with a CAI, you must always watch for puddles, and be careful with water splashing, with a "short-ram" none of this is an issue.
Old Jun 23, 2011 | 05:13 AM
CaptainAsia's Avatar
Use the snorkel with a cone filter...
e_kobz
18
May 4, 2015 07:20 AM
Mr. Evo X
Apr 26, 2015 05:56 PM
Cyrax91
Aug 3, 2010 11:27 AM
REVOlution86
Evo X Dyno Results
16
Feb 10, 2009 09:04 AM
Ben@AGP
13
May 27, 2008 08:25 PM
