Sponsored by:
Sponsored by: CARiD
BOV FLUTTER only WRX drivers want it.
Old Jul 12, 2011 | 03:54 PM
hackerrei's Avatar
Hello
I was checking around on BOV flutter when I came across this page I would have never thought any one would want the sound but these WRX owners block off there BOV to make surge. I was like WOW.
here is the post what do you guys think?
http://www.rexnet.com.au/forum/index...r/page__st__10
Old Jul 12, 2011 | 04:05 PM
Vivid Racing's Avatar
Actually, a lot of 240SX owners do it too. I personally love the sound, but last I heard the jury was still out on whether it would damage a turbo.
Old Jul 12, 2011 | 04:08 PM
Robevo RS's Avatar
i am not sure what is the flutter really means for others, but i have it in my car, since i got the VTA BOV. I have a Gems ECU so i am not running on OEM ECU anymore. Also it is actually make it even weirder when the ALS is on. ONly really get a solid strong psssh noise when i shift on throttle. As soon as i lift, the car more like flatters then just releases the pressure. Probably because the ALS is still keeping the PSI up over 12 psi even if i completely off throttle..
Old Jul 12, 2011 | 04:20 PM
Vostok 7's Avatar
Any time you shock something spinning at several thousand RPM, there's a high chance of damage happening at some point. Maybe if you were running a titanium or inconel turbine it wouldn't be so bad, but allowing flutter on stock equipment is probably not a good idea.
My STi had terrible flutter on both the stock BPV and the HKS SSQV I had. No matter how much I played around with the SSQV I couldn't get it to go away. I suspect that STi had vacuum issues, though, since it also had a boost spiking issue when a certain boost controller was installed that I couldn't fix.
- Patrick
the_evodude
Feb 23, 2013 09:39 AM
lpy2009
Feb 26, 2012 12:09 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
06GraphiteEvoIX
32
Mar 11, 2010 08:45 PM
evoseller888
16
Apr 27, 2009 03:55 AM
