Sponsored by:
Sponsored by: CARiD
"Evap Not Ready" on 2008 EVO X GSR
Old Aug 23, 2011 | 08:49 PM
calebduello's Avatar
I have a 2008 EVO X GSR and my emissions monitors are all ready besides the EVAP monitor. does anyone have anythings I can check? or how does it run or where are the hoses?
Thanks Caleb
Old Aug 23, 2011 | 08:58 PM
Mike Bones's Avatar
Did you clear any codes recently?
Old Aug 24, 2011 | 04:13 AM
Yeah I think so but there wasn't any about the evap system.
Old Aug 24, 2011 | 04:42 AM
4RETECH's Avatar
I guess you either disconnected the battery or cleared some codes recently.
Most EVAP systems will only operate within the 1/4 to 3/4 fuel tank range as the EVAP pump doesn't want to run too long or suck up fuel. Also it won't set on the first drive cycle. You have to drive it at least for a 20 minute session and then shut the car off for at least 4 hours. Over night is usually the best. Then start it up and drive like a grandma. No more than 50 mph in 5th gear at a constant rate. If you have a scanner have it plugged in so you know when it sets.
Good Luck
Old Aug 24, 2011 | 07:08 AM
ok I try that I didnt really know what the drive cycle was and I had been driving it a bit so I figured it was good but Ill try the 50 mph in 5th and see what I get. Thanks man.
Gtizks
Mar 2, 2016 04:48 PM
Justnii
Mar 20, 2015 08:09 AM
R717
Feb 28, 2014 11:56 AM
tjac357
Jul 13, 2012 10:48 AM
berkel
Nov 15, 2011 02:03 PM
