Sponsored by:
Sponsored by: CARiD
GSR heated mirrors?
Old Oct 24, 2011 | 02:17 PM
beantown's Avatar
heated mirrors
Suscribed to this thread. I recently bought heated mirrors from a member on this forum.
Old Oct 24, 2011 | 03:59 PM
DocWalt's Avatar
Originally Posted by Diversion
I'll be pulling some stuff apart to see if we have the wire/harness dangling in the mirror housing.. I don't understand why we would need the entire new mirror housing to get heated mirrors.. Especially if the wires are there, you can just solder up a wire(s) needed and do a nice job getting them work on your own.
The mirror assemblies for the heated mirrors have extra wirrors in them. Yeah, you could add them on your own, and I probably will. $180 a side isn't worth it to me.
Old Oct 24, 2011 | 04:23 PM
sgtr275's Avatar
You won't find anything dangling. It's just one wire in the already existing mirror harness.
Old Oct 25, 2011 | 12:22 PM
Diversion's Avatar
Sounds like an easy job to just add in the missing wire instead of buying the entire housing.
Old Oct 25, 2011 | 04:53 PM
OZ_2435's Avatar
really need these on my car
Old Oct 25, 2011 | 09:04 PM
sgtr275's Avatar
Sure. If you have the correct pin to add to the connector. Also, you have to figure out how to add the connector inside of the mirror housing for the heated mirror element.
Old Oct 25, 2011 | 09:28 PM
cla2000's Avatar
It should be a plain plug and play. I doubt you will have to add any pins or connect anything else than the harness itself. The car is prewired ans the heated mirrir assembly should also be wired so, you would just have to connect the plugs.
If you search ebay for lancer heated mirrors, you will find a lot of aftermarket ones for 50 to 90 $a side.
Regular lancers came with heated mirrors also, so finding a pair of those at a junkyard is not impossible
Old Oct 26, 2011 | 07:52 AM
Diversion's Avatar
I suppose you could pick up the aftermarket heated mirror housings and cut the harness out of this and use it on the factory housings to make the setup even that much easier, but you're still wasting money.
For the faint of heart, i'd just find a buddy or stereo shop that will wire them up for you, saving you about $300 total avoiding having the buy the entire MR housings.. The most this mod should cost is $140ish after ordering left and right heated mirrors /w the elements imbedded. There will be a wire coming off the element, this is the wire you will manually insert into the housing harness. You could even vampire clip it into the harness.
beetle_orange
Feb 23, 2016 04:18 PM
kitw
Dec 22, 2013 05:51 PM
solipsism
Evo X How Tos / Installations
40
Nov 5, 2012 07:00 PM
robevo8
Sep 26, 2011 03:40 PM
Billy's MR
Feb 1, 2011 05:46 PM
