Sponsored by:
Sponsored by: CARiD
evo 8 cams
Old Nov 18, 2011 | 05:19 PM
ryanholder24's Avatar
evo 8 cams
my car all the sudden died as i was drving it power steering went out and i checked the timing belt and the bottom turns over but not the top and the belt is fine just doesnt turn over idk whats wrong busted cam shaft ?
Old Nov 18, 2011 | 05:23 PM
DJAfterShok's Avatar
wrong sectiong. maybe you busted the belt, stripped it out kind of? Not sure... explain it a little clearer.
Old Nov 18, 2011 | 05:28 PM
the belt is fine just the cam shaft does not move at all when i try to start it
Old Nov 18, 2011 | 09:04 PM
Panda_stunter's Avatar
U sure the belt is fine?
Happened to my integra before and it was the timing belt. Let's just say, valves r f*cked. I needed to change the valves coz of a broken timing belt. Cam gears ok? Check anything and everything that makes the head move...timing belt, cams, pulleys....before u crank it again or it's gonna be at least a 1k job. Or cheaper if u do it urself.
SS1000RR
Feb 22, 2014 01:44 PM
Frew
Sep 26, 2012 07:38 PM
swalltr207jg
Jul 26, 2012 12:47 AM
gtpunk18
12
Aug 29, 2011 09:15 PM
jutilat
Apr 25, 2008 10:58 PM
