For those with aftermarket seats
I searched but couldn't find an answer, but I just got new seats for my car but they dont have airbag sensors in them so of course I get the light. So two questions. One if I do happen to get in a wreck will my airbags deploy? Two how can I get rid of the light on the dash. I have inspection in another month and I need to have the light off. Anyone have any suggestions?
The second part is correct, and there are posts as to how to run a resistor across the connector to shut off the light.
Something between 2.0 and 3.3 ohm will work (start with the 3.3 and then come down until it stops the light), but the key is making sure that they are at least a 1/8 watt resistors, with 1/4 watt being even better.
Do not be a pinhead and hook a multimeter up to the airbag to measure the resistance. Those things take very little current to fire and most multimeters will trigger them.
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
.MM
May 17, 2010 08:38 AM
aftermarket, air, airbag, bags, dummy, evo, find, hooking, installing, market, recommened, seat, seats, sensor, trick
