Sponsored by:
Sponsored by: CARiD
sputtering at partial throttle
Old Dec 11, 2011 | 12:30 PM
santeller's Avatar
I know this has been talked about before but i never really found the answer so figured id get some opinions..
Like title says whenever im boosting at partial throttle (5-12 psi) feels like the turbo is sputtering because i feel it in accel. But at 0 psi and wot pulls smooth. Any ideas?
mods: ams intake
TBE
FMIC kit
stage 2 ots ams tune
stock bov incase that matters??
Old Dec 11, 2011 | 02:29 PM
AV6JT's Avatar
since u have ams tune... id ask them?
Old Dec 11, 2011 | 02:47 PM
Iowa999's Avatar
Do you mean the stutter when you lift a little when at part-throttle?
Old Dec 11, 2011 | 06:53 PM
Fishstix's Avatar
This
Old Dec 11, 2011 | 08:45 PM
Rpf1evolution's Avatar
same thing happens to me id like to know. except i think its my ssqv acting up cause its wanting to blow off before i lift off the throttle enough to stay at constant speed and its making my car jerk alot
Old Dec 12, 2011 | 03:20 AM
santeller's Avatar
its basically without letting off throttle, keeping constant and consistent pedal pressure. just like what rpf1 said. And about the tune i should ask cobb? because its an AP tune. and im sure plenty of people are running very similar mods as me on here.
Old Dec 12, 2011 | 05:16 AM
Get Rad's Avatar
What gear are you in? I know that if you are in 5th and running at about 2000rpms you will get a flutter from the BOV especially when you start to accelerate. If that is the case just don't drive at 2000rpms while in 5th.
Old Dec 12, 2011 | 05:25 AM
redridingboost's Avatar
I had the same problem. I had a Greedy bov and as i switched to a stock 9 dv the problem stopped.
Old Dec 12, 2011 | 07:19 AM
derekste's Avatar
this.
if you want to get a complete picture, log accel pedal position, TPS, MAP, and your wastegate duty cycles.
usually, this only happens to me in 5th gear around 40-45mph (although if I went 25mph in 4th gear it would probably happen, too)
Old Dec 12, 2011 | 01:02 PM
santeller's Avatar
^ good idea ill try that. and could it be my bov??
Old Dec 12, 2011 | 02:02 PM
Get Rad's Avatar
The BOV should be fine just change your driving style.
1 evo8 1
33
May 8, 2020 02:14 AM
bryan32123
Feb 15, 2017 04:11 PM
anjapower
22
Apr 27, 2013 04:21 AM
rrkpitt15
12
Sep 11, 2011 06:59 AM
Red_Evolution
Apr 12, 2009 04:01 PM
