Sponsored by:
Sponsored by: CARiD
new guy, making a plan....
Old Dec 11, 2011 | 02:26 PM
northevo's Avatar
hi, let me start by saying sorry to mods if this is in the wrong forum.
i have an '11 GSR and my goal is anywhere from 320-350whp and 320-350wtq
reliability is huge because i live about 5 hours from the closest mitsu dealer and id also like the keep my warranty so if the car looks similar to stock my life will be easier. heres a list of mods id like and let me know if im dreaming or not...
-works panel filter
-ETS tbe (dealer said it was fine with that)
-ETS UICP
-Cobb turbo inlet hose
-Cobb AP so i can return to stock tune
-custom dyno tune from AMS assuming my afr is normal after those parts being installed and i can go a few weeks before my trip to chicago
i'd also like to know if i should really look into a boost controller (mbc or ebc)or just use ecu controlled boost pressure, im open to suggestions. i realize ams uses a mustang dyno but lets pretend ill be on a dynojet.
thanks.
Old Dec 11, 2011 | 03:00 PM
Kracka's Avatar
Get a 3-port boost control solenoid, but stay ECU controlled, no reason for external boost control. Your parts list sounds mostly good. I'd personally opt for an aluminum UICP to save weight and retain less heat though (Nisei, Cobb, AMS, etc.). I'd also do an open element intake that retains the stock MAF housing rather than a drop-in panel filter (AFE, Cobb, ETS, etc.).
I'm shocked a dealer said a turboback exhaust was ok though. Are you sure they realized you meant a complete turboback and not just a catback?
Old Dec 11, 2011 | 03:08 PM
ExtremeDSM's Avatar
You should be able to hit your goal. I agree with Kracka, aluminum pipes are much better than steel. Get as much weight out of it you can, they are tanks to begin with.
Old Dec 11, 2011 | 03:11 PM
northevo's Avatar
k thanks guys i read about ppl loving the grimmspeed 3 port any threads u can think of that explain exactly what it is and does?
Old Dec 11, 2011 | 03:28 PM
Kracka's Avatar
I have the Grimspeed, it's nice. I like the mounting bracket it comes with. It basically just controls increased boost levels more effectively than the stock 2-port solenoids do.
Old Dec 11, 2011 | 04:19 PM
EvilRob's Avatar
whats the weight diff between steel uicp and aluminum like 1lb?
Old Dec 11, 2011 | 04:25 PM
Kracka's Avatar
Definitely more than that.
Old Dec 11, 2011 | 05:47 PM
EvilRob's Avatar
I should have my uicp from ets by the end of this week so Ill weight it, if it weights 5 lbs and alum weights 3 lbs I still dont see it as a big deal.
Old Dec 11, 2011 | 05:57 PM
AV6JT's Avatar
too bad no dealer in california would ever be cool with tbe...
Old Dec 11, 2011 | 06:03 PM
Kracka's Avatar
Weight is weight, especially above the center of gravity.
Old Dec 12, 2011 | 06:35 PM
TheRedBaron's Avatar
^Just received my ETS UICP this past week, the shipping weight was 10lbs, I'd say the pipes, couplers and clamps are a minimum of 8-9 pounds. Sure, a bit heavy but the price and quality is right...
I too am shocked your dealer said a turbo back exhaust is fine.
Old Dec 12, 2011 | 06:55 PM
EvilRob's Avatar
Can you just weight the pipe alone? Also does anyone have an aluminum one they could weight so we could compare?
Old Dec 12, 2011 | 08:13 PM
northevo's Avatar
in alberta, canada there are no emission requirements unless u buy a car 10 years or older. even if i own the evo for longer than 10 years i wont have to get it tested. sooo the dealer isnt worried about by-laws, and unless they can provid physical evidence and proof that my mods caused a failure my warranty is valid. try as they may they have to present undoubted proof. although he did say a tune will completely void the car because mitsu programmed the car to run safely within its means.
Old Dec 14, 2011 | 12:02 PM
jlwEvo's Avatar
Registered User
NJ is super stingy too.
cerealkeller
Evo X Dyno Results
Sep 28, 2017 06:00 AM
juan.c.olivos
Evo X Dyno Results
Nov 5, 2015 01:21 PM
Krisko
Mar 10, 2014 06:49 AM
rmondoh
Evo X Dyno Results
35
Jan 12, 2014 04:08 PM
Risky Guy
Apr 18, 2013 10:13 PM
