Sponsored by:
Sponsored by: CARiD
To lower or not to lower....
Old Jan 13, 2012 | 05:41 AM
JBAutosports's Avatar
Just get the springs and alignment with your new tires. The Swift Springs are an excellent choice.
Old Jan 13, 2012 | 08:00 AM
CaptainAsia's Avatar
A little off topic, my buddy is getting swift springs for his MR. He said he'll sell me his old springs for cheap? Any difference between the gsr and mr stock springs?
Old Jan 13, 2012 | 10:06 AM
You would gain nothing from that. Save the money and get swifts or something else.
Old Jan 13, 2012 | 09:37 PM
shallowwhits's Avatar
I have the Swift Spec R's and they are a nice drop that closes up some of the fender gap but still looks almost stock to the untrained eye. They are a bit stiff and the handling was only slightly improved if at all. I just added the Whiteline RCK after having just the springs on for a year and the difference is very noticable. With the RCK I got the results in handling and steering feel I was looking for when I installed the Swift's in the first place. I would highly recommend doing the RCK with the Swift's at the same time since you will need an alignment after doing either one.
Old Jan 14, 2012 | 06:06 AM
Wheel gap "look" will have a bit to do with tire/wheel combo as well. Here is my car on normal Swifts. 18x10 +18 Wedsports with 275 wide tires. The combo works well IMO for someone looking for something aggressive that won't break the bank.
Old Jan 15, 2012 | 10:15 AM
ericjai113's Avatar
Thanks for everyone's valuable inputs, another follow-up question is can you still carry 4 people in the Evo after installing a set of mild drop springs like Swift?
Will you bottom out your car or hit the bump stop when you go over hump and dip on the road with 3 to 4 people in your car?
Old Jan 15, 2012 | 06:18 PM
You should be fine. What size wheel and tire combo are you running? Sorry if I missed it..
Old Jan 15, 2012 | 09:32 PM
ericjai113's Avatar
I am just running stock wheels and tires.
Old Jan 16, 2012 | 11:44 AM
The car is basically the same as stock after a mild drop like Swift springs...you can pull in/out of the same places without a problem and you are able to haul 4/5 people like before.
Old Jan 16, 2012 | 11:57 AM
Vivid Racing's Avatar
Yep, unless you start running bigger or wider wheels and tires, you should be fine. I carry Swifts and haven't seen anyone have rubbing issues on stock wheels/tires.
iseedipp
18
Jan 20, 2016 11:48 PM
PL_MR
12
Sep 25, 2013 06:36 PM
WRC-LVR
Apr 9, 2011 05:00 AM
Vivid Racing
Vendor Classifieds
77
Oct 29, 2010 05:01 PM
TempeRacerGuy
21
Aug 23, 2010 06:50 PM
