Sponsored by:
Sponsored by: CARiD
Made a stupid mistake :(, need some help
Old Feb 9, 2012 | 10:44 PM
MichaelUWright's Avatar
Angry Made a stupid mistake :(, need some help
So first of all I'm an idiot, ok thats that.
I was putting on some new brake pads and lines, should have all been easy and no big deal, the pads were but when I was installing the SS lines when I got to the driver side, I striped the nut connecting the first hardline that comes from the engine bay through the fender to the OEM rubber line does anyone know if that part is replaceable if I found out what part it was and ordered it? I havent looked thoroughly but it looks like one big hardline going from the passenger side out the driver side fender.
Old Feb 9, 2012 | 10:52 PM
SaulHudson's Avatar
You can try to re tap it, then when you put it back together, make sure you put some teflon tape on the male end threads. I understand you probably can't retap the whole thing since the line is in the middle, but you can tap enough, probably more than stripped.
Old Feb 10, 2012 | 05:18 AM
just1n020's Avatar
Did you get it off? If you didn't just use a pair of pliers or vise grips to remove it. If you know someone with a flare tool you can cut the very end off put a new nut on and flare it or buy a new line all together. Don't know how much the line is. Or if you are risky you could reuse the old nut by tightening it with pliers/vise grips. Good luck
Old Feb 10, 2012 | 01:59 PM
no i havent gotten it off yet, and ive tried vice grips, its not working. I dont know if it would be better to cut the hardline to get it to come off or replace the whole line
Old Feb 10, 2012 | 02:04 PM
SDevo13's Avatar
I'd just replace the line. Rather safe than sorry with brakes imo.
Old Feb 10, 2012 | 02:08 PM
Montu's Avatar
i stripped my flare nut on IX ordered the new hard line from mitsu for less then 15 bucks and installed it in maybe 15 minutes ..at least it wasn't a rear line!
Old Feb 10, 2012 | 02:09 PM
Revo15's Avatar
^ I AGREE just replace it..brakes is something you dont wanna mess around with.
Old Feb 10, 2012 | 05:12 PM
alright I just ordered the hardline at south coast, thx for the input guys
Old Feb 14, 2012 | 07:07 PM
I replaced the line, ........wasnt ****in very pleasant haha. Thanks again
