Sponsored by:
Sponsored by: CARiD
Grimmspeed ok with stock tune?
Old Feb 21, 2012 | 12:11 PM
mct9891's Avatar
Ordered a few parts and wondering if I should wait till I get tuned to install the Grimmspeed 3 port or is it perfectly fine to install before tune?
Old Feb 21, 2012 | 12:17 PM
Ikamono's Avatar
I'm wondering about this too.
Old Feb 21, 2012 | 12:19 PM
gsrdc2's Avatar
from what i've read it has to be tuned. i would just have the tuner install at the time of the tune.
Old Feb 21, 2012 | 12:26 PM
BCOZEVO's Avatar
No.
Do not install it until your ready to be tuned. The boost tables in the ECU require a completely different setup.
Old Feb 21, 2012 | 12:40 PM
b16a2delsol's Avatar
No ! Lol unless you want to see pieces of your motor all over the road.
The stock bcs works by using 100% duty cycle during full boost with restrictor pills to avoid over boosting. Using a 3-port and the same duty cycles would mean essentially maxing out your turbo.
Old Feb 21, 2012 | 12:43 PM
PRS's Avatar
PRS
It would be completely pointless without a tune.
Old Feb 21, 2012 | 06:36 PM
bluaeon's Avatar
if you have read their instructions, you would know that you need a tune when you install this.
Old Feb 21, 2012 | 07:43 PM
Get Rad's Avatar
Get a tune!!!!!!
Old Feb 21, 2012 | 07:47 PM
tscompusa's Avatar
definitely not.
Old Feb 21, 2012 | 07:48 PM
Get Rad's Avatar
Does a Cobb tune count?
Old Feb 21, 2012 | 07:50 PM
tscompusa's Avatar
this . lol. the only thing that will attempt to save it is BEC table.
Old Feb 21, 2012 | 07:52 PM
tscompusa's Avatar
if the cobb tune is designed for a 3 port and is set properly then i dont see why not.
Old Feb 21, 2012 | 07:55 PM
Get Rad's Avatar
I may have to call up Cobb on this one.
Old Feb 21, 2012 | 08:04 PM
lathiat's Avatar
Long story short, if the tune is working fine with your standard solenoid.. It will not work with the 3-port. You will have to change tunes.
If you really want to install it before going to the tuner, you could run your wastegate straight to the vacuum/boost line that otherwise runs to your solenoid (bypassing the solenoid), which would make your wastegate run at spring pressure until you swap it back to start tuning. Then just temporarily block off the other lines. Someone please confirm my logic on that
Old Feb 21, 2012 | 08:33 PM
BCOZEVO's Avatar
Do you have a AP? If not just have a tuner do a eflash for you.
