Sponsored by:
Sponsored by: CARiD
Scheduled Maintainance tips
Old Mar 12, 2012 | 03:31 PM
AntiVirus42's Avatar
Hey guys,
Nothing special here just wondering what kind of preferences everyone has as far a scheduled maintainance. Im about to hit the 30k mark. I change my oil myself and regularly and Ive thumbed through the manual on what the dealership reccomends. My question is what things if any do you like to do early/more often. Replacements/flushes/ect. I do not drive my car hard on the road but I do drag and road course it once or twice a month. Full bolt-ons stock turbo stock block. 340hp/330tq. Thanx alot
Old Mar 12, 2012 | 03:48 PM
wicked white14's Avatar
Well, I weould def take a look at the 4 fluids under the car after they have been replaced at 30,000 miles. While mine is a DD, I had a local shop, who is familiar with EVO's, do the fluid change and that crap was N-A-S-T-Y........prolly do the fluid change every other year now, even though it is driven only 5,000 miles per year.
Old Mar 12, 2012 | 08:28 PM
Thanx Man. Fluids are def on my hit list. I was wondering if I should pay more attention to the transfer case and stuff
Old Mar 12, 2012 | 10:41 PM
iEvolutionX's Avatar
I have always done all major/minor maintenance on all of my cars and it always feels good to know it was done right. Here is my .02
@ 30K miles
Need to change:
- Engine Coolant (50/50 ethylene-glycol base products for aluminum component protection)
- Transmission Fluid 3 quarts (Amsoil 75w-90 GL4 or Mitsubishi Diaqueen Multi Gear Oil 75W-80 API GL3) ** Some people use a redline "cocktail" mixture as a remedy for "notchy-shifting" but YMMV.
- Transfer Case Fluid 0.9 quarts (Diaqueen LSD Gear Oil)
- Rear Differential Fluid [Differential Mechanism] .58 quarts (Diaqueen LSD Gear Oil)
- Rear Differential Fluid [Torque Transfer Mechanism] .58 quart (Mitsubishi Diamond ATF-SP III)
Inspect and change IF necessary:
- Drive Belt (aka. Serpentine/Accessory Belt)
- Air filter
- Cabin Air Filter
- Brakes (rotors and pads)
- Suspension components (esp. Worn bushings and CV boot for leakage)
** Important ** Make sure to buy new "crush" washers for all of the drain and fill bolts. This includes the washer for:
- engine oil drain bolt
- transmission fill bolt
- transmission drain bolt
- transfer case fill bolt
- transfer case drain bolt
- differential fill bolt
- differential drain bolt
- differential "torque transfer mechanism" fill bolt
- differential "torque transfer mechanism" drain bolt
I know its a lot of washers, but to end up with a proper torque for each of the bolts, using a new crush washer is highly recommended.
And the best part about it all: At the end of the night, you can sleep well knowing that it was done right.
For reference:
Old Mar 14, 2012 | 05:17 PM
Thanx soooo much guys. Very helpful
Old Mar 14, 2012 | 05:20 PM
Kracka's Avatar
Any modified car, especially one that see's even occasional track duty, absolutely needs to follow, at the very minimum, the severe duty maintenance schedule.
Old Mar 14, 2012 | 05:39 PM
Alpha X's Avatar
I've been wondering about this as well. I'm coming up on my 15k service.
Old Mar 15, 2012 | 05:08 AM
Johnr352's Avatar
Well said, and at least. And why not, fluids, in comparison, are cheap.
hearnoevo
For Sale - Cars For Sale
Mar 17, 2017 06:27 PM
EvolutionRacing
Jul 20, 2016 02:06 PM
EvolutionRacing
Jul 14, 2016 04:12 PM
vassili
Mar 19, 2010 12:00 PM
EvolvedMR
Jan 1, 2009 08:27 AM
