Sponsored by:
Sponsored by: CARiD
AEM Intake [My spin on it]
Old Jun 20, 2012 | 11:59 PM
  #31
hkumar's Avatar
Lightbulb
Speaking of AEM CARB sticker, apparently the AEM intake is now road legal for the 2010 models (not 2011 or 2012 yet). So I am just going to keep a print out of this in my car, once I install the intake.
http://www.aemintakes.com/store/appl...x?Prod=21-678C
http://arb.ca.gov/msprog/aftermkt/de...eo/D-670-6.pdf
Old Jun 21, 2012 | 10:18 AM
  #32
busky2k's Avatar
Interesting result regarding the power drop with the lid attached. This seems to indicate that the snorkel is somewhat restrictive although that seems odd since collective surface area of the snorkel's narrowest point ~ equals a 2.75-3" pipe. This makes me wonder if the AEM with the lid on would flow much more than a stock intake would? Thanks for sharing the results!
Old Jun 21, 2012 | 10:21 AM
  #33
zwampy's Avatar
The reason we tried this is the tuner had done this previously with same intake on a different car with similar results -- so he recommended and actually proved it as seen in the dyno plot.
So all in all, no lid for me
Old Jun 21, 2012 | 10:28 AM
  #34
busky2k's Avatar
Yep, nice test
Btw if you do decide to keep the lid on, I believe one problem with the snorkel is that its high up in the box which makes it more difficult for the 'underside' of the cone filter to access incoming air, creating a relatively negative pressure at the base of the box. If you're planning to drill a hole in the airbox instead, maybe one at the base of the box would offset it slightly. Just an idea. Cheers.
Old Jun 21, 2012 | 10:54 AM
  #35
EuroEclipse's Avatar
Maybe you can make your own version of the ARC intake box. K&N cone in place with a mesh screen on top and side... If that's a stupid idea then just ignore that.
Old Jun 21, 2012 | 12:08 PM
  #36
RazorLab's Avatar
Originally Posted by busky2k
IThis seems to indicate that the snorkel is somewhat restrictive
I posted about this awhile back, at higher airflow, the OEM snorkel has so much restriction, it causes the AEM induction tube to collapse:
https://www.evolutionm.net/forums/ev...aught-log.html
Solution was to take the lid off the AEM box and problem went away.
Old Jun 21, 2012 | 12:35 PM
  #37
EvoLoverForever's Avatar
zwampy aem's carb sticker doesnt apply to your car. so it might help you get away if you get pulled over, but you still might have trouble in case anything happens.
So either way you can do what ever you want.
http://www.aemintakes.com/search/app...x?Prod=21-678C
I am curious though, what if you do a cutout on the top of the plastic? or drill some holes on it?
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
