Sponsored by:
Sponsored by: CARiD
driving light dont work?
Old Apr 17, 2012 | 07:12 PM
dsmturbo87's Avatar
My driving light is out but my headlights stll work .. which bulb do I get and how do i go about fixing it?
Old Apr 18, 2012 | 06:19 AM
laxplayer14's Avatar
driving light??? you mean day time running lights? if so, they are 1156 if i remember correctly. go to sylvania's website and look up bulb sizes or your manual
Old Apr 18, 2012 | 08:54 AM
ugakirk's Avatar
Could be the fuse too if both of them went out at the same time. I think it was no.13 under the good.
Old Apr 18, 2012 | 01:04 PM
dsmturbo87's Avatar
Im sorry i should have been more specific..
It IS just ONE SIDE daytime driving light
I will look into syvania's website
I cant locate where the bulb even is or what need to be take off? ie: front bumper
Old Apr 18, 2012 | 04:20 PM
ithveno339jfkj4kjekjqqqq's Avatar
from the inside/out, you have turn signal (7443), DRL (1156), headlight, parking light
if you pop the hood and look at the back of the headlight housing, directly behind where the DRL is, there is a big cap (about the size of your palm) that you have turn counter-clockwise to remove... then you can access the 1156 socket, which you also need to turn counter-clockwise to remove.
the driver's side has less room, so hopefully you have small hands (or know someone who does).
Old Apr 18, 2012 | 05:31 PM
yea im not sure but when i swapped yellow nokya drls on mine not too long ago, i think i unclipped an ac line and may have unhooked the coolant reservoir to try to make a little extra space. i also timed it when i removed the stock airbox for an ets intake because there was no way i could fit my hands in between on the driver side.
Old Apr 18, 2012 | 05:53 PM
dsmturbo87's Avatar
ok ill see if i can find it again
Evolution_10
Dec 17, 2013 02:39 PM
mikegutt
Mar 5, 2012 01:26 PM
Rotten Egg
Oct 26, 2011 05:16 PM
EvoGate667
Dec 21, 2008 10:01 PM
shuttlegoose
Oct 2, 2008 05:40 PM
