Sponsored by:
Sponsored by: CARiD
Blow off valve question
Old May 22, 2012 | 07:55 PM
bluaeon's Avatar
Hi guys. Just a quick question. Other than stock BOV, what else out there is comparable to stock bov or better than stock but will not break my wallet. Reason is, i think my stock one is broken.
Can anyone tell me what a broken bov sounds like or how my car will act like? I think when im on boost, its open partially instead of closed until i let off the gas. Basically, what are the symptoms of a broken BOV? Thanks guys.
Old May 22, 2012 | 10:39 PM
EuroEclipse's Avatar
If it's broken the car will feel more sluggish and not as quick. It will also flutter, and you can hear it open while under throttle.
Old May 23, 2012 | 08:55 AM
TheBlade's Avatar
If your basing this only on the fact that your boost tapers as you approach redline, that is normal. The stock tune will peak like 23psi and then back down to 16/17psi as you approach redline.
Best way to tell if it's leaking is to datalog really. A tuner can see what the target is per rpm and then if it's not holding you can see. However, it is probably easier to just borrow someone's OE DV and go for a quick drive since it really is easy to swap on the Evo.
jmoney2001
May 24, 2017 02:35 PM
Pawl7
Mar 2, 2014 09:53 AM
reboundicon
Apr 20, 2011 04:20 PM
Solo Evo
Sep 22, 2005 01:55 PM
NRG
34
Sep 28, 2004 10:15 PM
