Sponsored by:
Sponsored by: CARiD
Works Short Throw
Old Sep 30, 2012 | 01:57 PM
  #46
NOSintake's Avatar
Originally Posted by cla2000
What is better aluminum bushings or polyurethane? I wish I could just make up my mind. I am set on the works shifter. Maperformance sells it for 165. I am just not sure about bushings.
I'm in the same boat. I originally wanted the TWM complete kit, but WORKS seems to get better nods overall.
Old Sep 30, 2012 | 04:01 PM
  #47
spadednick88's Avatar
Ive heard alluminum is best. There both good but metal ones have less play i guess. And uf u look ams and them only sell metal ones so thats what i went with
Old Sep 30, 2012 | 04:07 PM
  #48
Kreeker's Avatar
The shifter throw is reduced by 25%, do you guys notice that it requires 25% more effort to shift, or do you not noticed it?
Old Sep 30, 2012 | 04:13 PM
  #49
I havent tried it yet but ive heard nothing but good things about it. I heard its quite the difference from stock
Old Sep 30, 2012 | 05:13 PM
  #50
Kracka's Avatar
where is the best place to get the works from? i am also interested in it.
http://www.maperformance.com/krackas...shi-evo-x.html
How important are those bushings? I am looking at the works site and for a complete set is 250.
This http://store.worksmotorsports.com/WO..._p/420.111.htm
Or this
http://store.worksmotorsports.com/Pr...03%5F642%2E104
The second link includes the knob that I dont need.
As long as you're doing a shifter, you might as well complete the setup so it's as good as possible.
Polyurethane; less noise and no corrosion/binding issues to deal with as the bushings age in the elements. I've tried every type of shifter bushing available and I am set on the urethane. If you do get metal, plan to remove, clean, and lubricate annually otherwise it's likely they'll seize and start binding up your shifts.
Slight increase in effort but by no means heavy or stiff.
Old Sep 30, 2012 | 05:44 PM
  #51
Just wondering, how would base bushings corrode inside the car?? Also they are alluminum witch is pretty corrosion resistant.
Old Sep 30, 2012 | 05:48 PM
  #52
Kracka's Avatar
I was referring to the underhood cable bushings.
Old Sep 30, 2012 | 05:52 PM
  #53
Oh ok ya i could see using poly under hood that makes since. i just heard metal on console are better because they dont budge like poly would but i font have any experience so thats just a guess
Old Sep 30, 2012 | 06:10 PM
  #54
NOSintake's Avatar
So poly underhood and metal everywhere else? Or is it best to just go poly all around?
Old Sep 30, 2012 | 07:04 PM
  #55
cla2000's Avatar
[QUOTE=Kracka;10428662]http://www.maperformance.com/krackas...shi-evo-x.html
Slight increase in effort but by no means heavy or stiff.[/
Thank you for your help. Your kit is 500. a little to much for what I need now. Is this all I need as far as the bushings go? http://store.worksmotorsports.com/Pr...03%5F642%2E104
If I get that, and than the trans mix, and The AMS EVO X 5 Speed Gate Selector Bushing Kit from maperformance I will be at 321.8$.
I just want to make sure I am not missing any bushings going this route.
Thanks for all the help and contribution to this forum Kracka.
Old Sep 30, 2012 | 07:24 PM
  #56
Kracka's Avatar
Well, my recommendations are included in the kit I've put together, but if you want to do aluminum console bushings that'll be fine too and probably make minimal difference either way.
Old Sep 30, 2012 | 07:25 PM
  #57
Kracka's Avatar
Yeah, that'll be fine too, then you can just add the driveshaft and rear diff bushings later on when you're ready to add something new.
Old Oct 3, 2012 | 05:17 PM
  #58
4ever Boosted's Avatar
Great shifter i love mine.
Old Oct 13, 2012 | 10:18 AM
  #59
cla2000's Avatar
I need help. I just got my works shifter and I want to install. I just cant find a good diy for removing the console plastics arrownd the shifter. I looked on the twm instructions but my center console is different than the one they are using. Also, how do I remove the aluminum stock shift knob? I tryed unscrewing it but wont budge. I did try counter clockwise. Thank you in advance.
Old Oct 13, 2012 | 10:37 AM
  #60
Johnr352's Avatar
sawzall
