Sponsored by:
Sponsored by: CARiD
Clutch problem
Old Jul 24, 2012 | 06:50 PM
Kidtkd73's Avatar
Clutch problem
Hey guys I was driving today at about 15 mph and went to shift from 1st to 2nd and all the sudden my clutch pedal just dropped all the way to the floor. I would move the pedal either all the way down or all the way in the up position. The car starts when the clutch is pushed in but I can't change gears and it won't start when it's up. If anyone knows anything about this any info would be great! Thanks in advance
Old Jul 24, 2012 | 07:01 PM
Phantom83b's Avatar
Your clutch is gone...blown...dead.
Old Jul 24, 2012 | 07:06 PM
XFTW's Avatar
Yep toast!
Old Jul 24, 2012 | 07:10 PM
Panda_stunter's Avatar
It's not the clutch, it's either the clutch master cylinder or the clutch slave cylinder. Change it to the Magnus cmc kit or something similar. Coz u say it doesn't have any pedal pressure right?
It could be another thing like ur throw out bearing popping off. But my honest opinion is either of the clutch cylinders, master or slave.
Old Jul 24, 2012 | 07:14 PM
RoMeIX's Avatar
It does sound like your clutch is gone man, good luck getting everything dealt with.
Old Jul 24, 2012 | 07:22 PM
ugakirk's Avatar
This guy is right, but I think the others could be too.
When you say that the pedal dropped all the way to the floor, that is usually what happens when the CMC goes out. It's a cheap plastic one that Mitsubishi used on the Xs. They clutch MAY need to be replaced too, but it could just be the CMC. pm MAP for a good deal on the AMS CMC unit.
Old Jul 24, 2012 | 07:27 PM
Kidtkd73's Avatar
It's a stage 2 clutch that was put in 3000 miles ago
Old Jul 24, 2012 | 07:30 PM
When the clutch disk itself is gone, u slip...u would still have pedal pressure though it will be soft. If the CMC or CSC is bad, u get no pedal pressure at all. I know this coz I have a 350Z that had a problem with the slave cylinder. Good thing there was a recall for it from Nissan USA. What ur talking about is the same symptoms I was having when my slave cylinder went out on me.
I also know that it's not the clutch itself coz I just changed my slipping clutch.
Old Jul 24, 2012 | 08:41 PM
MisterHappy's Avatar
Just happened to my boy recently. Sounds like your clutch master cylinder, get the magnus as said above.
Old Jul 25, 2012 | 05:26 AM
Phantom83b's Avatar
Yeah i should of mentioned the cmc as well. I'm a big fan of ams, and they make a great cmc.
Also I see unsaid u just put one in 3k ago, but remember, it doesn't matter how new it is. If u beat on, or launch it frequently, it will die. Drive it smart or be prepared to constantly spend$$$$ to replace it
Old Jul 25, 2012 | 05:30 AM
Jookies's Avatar
You just put in a stage 2 clutch, but the clutch has too much pressure for the stock CMC. That's why the clutch is so new, but you had this issue.
Edit: in this case it doesn't matter how hard you drive the car, or even if you baby it, the CMC still can't take the increased pressure.
roni4g63
May 21, 2020 07:43 PM
Kris86
Oct 5, 2016 10:31 AM
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
jonzie04
May 22, 2012 12:41 AM
Dubius
Feb 25, 2008 05:09 PM
