Sponsored by:
Sponsored by: CARiD
Hesitation while accelerating
Old Aug 10, 2012 | 05:49 AM
Alkaedas_Inc's Avatar
I have a 2010 GSR, and it has happened to me a few times when I take the car out on first gear the car will start hesitating when boosting, full throttle.. It usually does it like the first run after I turn it on, but then if I accelerate again it responds normally.
Anyone has had this issue before, Any suggestions??
Only Mod I have is CNT 3" Cat Back Exhaust
Old Aug 10, 2012 | 08:07 AM
S2K2EVO's Avatar
Check the FPR hose. That can come loose and cause havoc. Mine and many others zip tie the hose. You might make sure you have the most up to date fuel pump relay as well.
hawaiianstyle's Avatar
Car isn't warmed up and turbo isn't either. Let the car warm up for 5 mins or so. Don't ever boost before your car is warmed up, you'll start having more issues if you keep doing that.
Old Aug 10, 2012 | 11:02 AM
toshibakoludo's Avatar
Thats true ^ in warm weather u don't need to let it idle long but 1-2 minutes should be fine. Than you just take it easy for a minute or two and should be having no issues that you described.
Old Aug 10, 2012 | 11:06 AM
Also, remember you have mivec which if not warmed up won't work properly either.
Old Aug 10, 2012 | 11:54 AM
Evolution Z's Avatar
well if it happened repeatedly, id say clutch... but it doesnt... soo no idea
Old Aug 10, 2012 | 11:59 AM
ugakirk's Avatar
I think he isn't letting it warm up properly like stated above.
^^My first thought was maybe the clutch slipping too when I read the title..
Dmx3alo
Jul 14, 2024 12:44 PM
BOOSTEZ
168
Aug 15, 2019 06:12 AM
GSREVOx
Oct 18, 2015 08:24 PM
boost_dependent
17
Mar 5, 2012 11:09 AM
