Sponsored by:
Sponsored by: CARiD
Why an EBC
Old Aug 28, 2012 | 07:52 AM
tonerockyhorror's Avatar
Why an EBC
Hey guys, I'm new to the forum and have been trying to figure some things out. I've read a few threads on EBCs and MBCs and am still having trouble piecing together whether it's really necessary.
If I'm doing simple boltons (TB + Intake) and have a Cobb AP that I'm looking to get tuned, what will an EBC do for me? Is it necessary or just a nice to have for fine tuning?
Thanks.
Ryan
Old Aug 28, 2012 | 08:25 AM
xTiCkxMYxLaInTx's Avatar
MBC:
1. Cheap
2. Can control boost easily with a few pulls to test.
3. Hard to have different boost levels. Well.. the Forge has a click sound for every turn making it easier to set a few boost levels.
4. Had to go to the hood to adjust unless you get one installed inside the cabin.
5. You can have boost spikes and taper
EBC:
1. Not cheap
2. A little harder to setup boost and more parameters to deal with.
3. Very easy to have 2 to 4 different boost levels.
4. Very easy to switch between boost levels.
5. There is a reduced boost taper. Have better control for boost spikes. If you want them... you can have the spikes or you can reduce them.
I think if you are going to change boost levels often then an EBC might be better
Old Aug 28, 2012 | 08:26 AM
Kracka's Avatar
For the X, neither; ECU-controlled 3-port BCS.
Old Aug 28, 2012 | 08:29 AM
+1
Old Aug 28, 2012 | 08:46 AM
What does the BCS actually do? Is it just something that would give a tuner more flexibility in tuning different boost levels?
Old Aug 28, 2012 | 08:47 AM
I guess I'm struggling to understand why this is actually necessary. I come from the Subi world where you buy a Cobb AP, have it tuned and you're done. No one uses boost controllers or solenoids. Why is that not the case for X's?
Old Aug 28, 2012 | 08:55 AM
tkromer's Avatar
You don't have to add a boost controller to an X at all.
The solenoids help you control boost a little more quickly using the stock ECU, but absolutely not required.
Old Aug 28, 2012 | 08:57 AM
Kracka's Avatar
You can keep the dual stock boost control solenoids if you want, but an aftermarket 3-port solenoid is much easier for a tuner to adjust, set, and hold raised boost levels.
Old Aug 28, 2012 | 11:40 AM
Got it, that makes sense. So it seems like a "nice-to-have" but not a necessity in initial modding.
Thanks for the help guys.
Old Sep 2, 2012 | 09:40 PM
evo warrant's Avatar
AccessPort. It is a 1000 times safer.
Old Sep 29, 2012 | 05:10 PM
fnlygotboost's Avatar
had a forge MBC, useless
had a go fast bit EBC, useless
End result - spikes to 33 lbs - broken rod - car goes back to bank - yeah
EvoNo0b
Mitsubishi TC-SST Discussion
Feb 28, 2017 12:16 PM
JJwins
May 5, 2016 10:27 AM
efmathis
16
May 9, 2015 06:37 PM
GgreyEVOIX
Nov 23, 2005 11:05 AM
zstryder
22
Mar 15, 2004 08:54 PM
