Sponsored by:
Sponsored by: CARiD
TWM Full Replacement Short Shifter Cage
Old Oct 2, 2012 | 11:35 AM
TWM Performance's Avatar
You guys should come check out our latest thread! We're offering a mystery item when you purchase our Shifter Cage for your EvoX! Come check us out
PM or EMAIL for pricing and details!
Renato
Team TWM Performance
Old Dec 13, 2012 | 11:36 AM
davey111483's Avatar
i just installed mine two days ago and the difference was night and day. the shifts are more precise. it requires more force when shifting since i also bought the cable and transmission bushings. i had a problem with the transmission bushing since i forgot to put grease on it but once i did, it was so AWESOME!
Old Dec 13, 2012 | 12:08 PM
This is great to hear! We're glad to see yet another satisfied customer We're glad to be able to provide you the best quality and engineering on the market. Send us pics of the finished product and we'll post it up on our social networks!
Renato
Old May 27, 2014 | 05:14 PM
omiwu's Avatar
I purchased TWM Transmission Arm Bushings, so where should I put this on? sorry for this silly question.
Old May 28, 2014 | 05:59 AM
kosteniuks17's Avatar
This might be a stupid question, but could you perhaps get the twm shifter cage and put a works short shifter into it, or no?
Old May 29, 2014 | 09:09 AM
Alien Visitor's Avatar
Yes, that's what I have.
Old Jan 25, 2015 | 06:23 PM
blooo's Avatar
I know this is an old thread, but I wanted to share a couple of learnings that might help someone out. First, you can purchase the plastic cup that goes on at the bottom of the shift lever directly from Mitsubishi, which will save you all the time/effort of taking your stock shifter assembly apart. Second, the TWM kit does not include lock washers and you cannot reuse the stock ones because they are not removable from the stock bolts. You can just buy four size M8 lock washers from your local hardware store for less than a dollar. <BR>With regards to the shifter itself, the difference is definitely night and day. The throws are much shorter and definitely feel more precise. However, be aware that shifting will be significantly stiffer. I have problems with my shoulder so it is making it slightly uncomfortable. I am sure this wouldn't bother the average person, just in my case because of my shoulder problems, but just an FYI
Old Jan 26, 2015 | 12:54 PM
Thank you very much for bringing this to our attention, we greatly value your input. Due to your post, we have now decided to include M8 lock washers with ALL our Evo X Full-Replacement Short Shifter Kits effective immediately. For all new posters, this is what all the fuss is about
Best regards and happy shifting!
Renato
Old Feb 2, 2015 | 08:28 PM
Dr.G's Avatar
Hey guys just wanted to post that I recently had the TWM shifter cage and all I can say is WOW!.. This is exactly how the evo should have come out of the factory. Like i read a few posts before me the shifts have purpose now and you can feel engagement. I really do think it is one of my best mods thus far and I have quite a lot. So if you have a clunky shifter and have problems getting into 2nd or notchy 3rd this is the solution. Great product TWM..thanks for the R&D
Old Feb 2, 2015 | 09:31 PM
yifuqiao's Avatar
Glad u like it man.
I have gathered some infos that 2014 EVOs probably doesn't like this TWM full replacement.
I have tried a 2010 X with twm full replacement before and it was Amazing.
However, I did the exact same setup on my 2014, and it is a ***** to shift. I also noticed that there is at least 1-2 members in Notchy trans thread stated that they didn't think TWM full replacement improved the shifting on their 2014 X as much as others have stated. So, I am not alone.
Not against TWM, but I personally don't recommend this to any 2014 EVO Xs.
Old Feb 3, 2015 | 10:48 AM
Thanks for sharing your love for our product! We take tremendous pride in the Evo X Full-Replacement and we're glad that it translates to our customers. Thank you for your continued support!
Originally Posted by yifuqiao
Glad u like it man.
Thanks for bringing this to our attention. We are saddened to hear that this is the case for you. Please send us an email so we can work on finding a solution for you and the other members experiencing this issue. We want to make sure you and the other members can experience the TWM Performance shifting feel which we are so well known for. Send your inquiry over to: info@twmperformance.com.
Best regards,
Renato
Old Feb 3, 2015 | 11:01 AM
yifuqiao's Avatar
Best regards,
Renato
Thanks TWM for standing behind your products.
I will take a video for you tonight and send it to you guys with some links to the forum threads I have found.
Old Feb 3, 2015 | 08:21 PM
Dr.G's Avatar
Ok let me be a bit more specific on my full set up..My evo is a 2011 and I have a works short shifter kit with TWM bushing kit and TWM shifter cage....it works wonders for my car. I have read mixed reviews based on year but i didn't know that drivetrain changed that much over the years.
Old Feb 4, 2015 | 03:52 AM
Robevo RS's Avatar
well ... i have a 2008 and a 2014 GSR, and the drive train didnt changed.
Old Feb 4, 2015 | 10:30 AM
yifuqiao's Avatar
Nobody said the drivetrain changed.
But I am not surprised if they changed linkage, pivot arms or bushings for certain cars.
Here is a response I got from TWM last year after I installed pivot bushing:
TWM Performance <sales@twmperformance.com>
9/25/14
to me
Hello Yifu,
This issue surfaces from time to time with certain EVOX cars, not all of them. During the manufacturing process it seems like 2 slightly different cables arms were used on the EVOX, our bushing works on both but one model has to break in a bit before it will perform properly. What we suggest to help the break in is to use a lot of grease on the main pivot pin that goes through the bushing this will help loosen it up and in a little while the bushing wears into its place correctly. With a bit of use your shifter should start coming back into the center on its own.
We hope this helps,
Cheers,
John
