Sponsored by:
Sponsored by: CARiD
How to make the shifter better?
Old Sep 3, 2012 | 02:44 PM
AGinHD's Avatar
Originally Posted by evokerfes
Yeah, that package is good. I probably would've gone with that if I didn't buy everything seperately
If you want to make it a little bit more complete, you should get this:
http://www.amsperformance.com/cart/a...shing-kit.html
After installing it, I could "feel" the gates more. It added a more positive feel to the shifter.
Some people experience lockouts or notchiness when going WOT and shifting. A stiffer front motor mount will help with that. I have one installed in my car and it makes WOT shifting buttery smooth. However, it will add cabin vibrations and you will especially feel it when you run AC. I use the 70A durometer AMS front motor mount.
http://www.amsperformance.com/cart/A...e-Pressed.html
If you want to tighten up the shifter even more, you can get the TWM cage for the Evo X. I don't have it installed on my car nor do I feel it's necessary for daily driving
http://www.twmperformance.com/shorts...rtshifters.htm
Ohh wow okay thanks! I used to have motor mounts on my old car and it annoyed the hell out of me. I would be vibrating so much at stop lights and stuff lol. Dont plan on doing those ever again!
Old Sep 3, 2012 | 02:48 PM
AGinHD's Avatar
Yeah the Blox 490 is a great shift knob that is heavy and is more affordable.
What do you guys think of these shift knobs?- http://www.bloxracing.com/bloxshop/i...product_id=413
Personally I think they look better then the round ones lol
Old Sep 3, 2012 | 02:56 PM
Sev's Avatar
Sev
Like the S2K style ones? Pretty cool.
Old Sep 3, 2012 | 05:46 PM
350BAZ's Avatar
Works SS
Works base bushings
Torque solutions gate selector
Torque solutions under hood bushings
Flossy Heavy
I love the set up, stock felt like i was driving a manual truck.
Old Sep 4, 2012 | 06:37 AM
EvoX4life's Avatar
I had the blox490 on my car. Thing weighs a ton and I loved it haha. For ****s and giggles the one day I put back on the stock knob and shifting just was not as smooth. I def suggest the blox490. Also I had the works short shifter w/ both bushing. No complaints here at all with that setup especially since it brings neutral where 2nd gear is stock basically. Here good reviews on both works and TWM though. I would stick with one of those.
Old Sep 4, 2012 | 07:05 AM
ogrenator's Avatar
I have the GR>G Heavy Wheight carbon fiber knob...its 1.1 lb...and the Works short shifter....before I put the shortshifter on...the knob made a HUGE difference with the stock throw...shifted smooth as butter....then after I put the shortshifter on it evened it out a bit b/c of the more work required to shift....
http://www.getnrg.com/products/shift...hift-knob/feed
shot with both installed...and new shiftboot
Old Sep 4, 2012 | 08:42 AM
AGinHD's Avatar
Wow that looks sweet! Is the thread pitch 12.5?? All the type R shift knobs I see are always only 12.25 lol
Old Sep 4, 2012 | 08:48 AM
evokerfes's Avatar
Evo X's shifter thread pitch is 10 x 1.25
Old Sep 4, 2012 | 08:50 AM
ogrenator's Avatar
its a universal knob so it comes with 3 inserts...most people say knobs like that are garbage...but I couldnt find another heavy knob that looked like this so I took the plunge...basically you use a screw to attach the insert to the knob then you have to thread it yourself...took about 5 mins to do and ive taken it off an back on a few times and have had no problems with it being loose on the shifter...the ONLY issue I had was after about 2 weeks the insert became a little loose inside the knob...and by little I mean like half a MM...so to remedy this I pulled the sucker off and wrapped two layers of electrical tape around the south tip of the insert(the bottom of the knob) this was months ago and the knob is rock solid.
and apparently I managed to link the wrong knob in my post lmao...
http://www.getnrg.com/products/shift...ght-style/feed
Old Sep 4, 2012 | 10:32 AM
AGinHD's Avatar
Ohh is it really? I GOT SOME MISLEADING INFO THEN!! lol
Old Sep 4, 2012 | 11:52 AM
Get Rad's Avatar
Do a search for Krackas review of the works shifter and the TWM . It was a great write up he did and really helped me with my finally decision. I have the complete works upgrade for mine and love it. It was like night and day after the install and the install was really easy and fun.
Old Sep 4, 2012 | 11:59 AM
Wildcat Birdie's Avatar
already links posted above.
Old Sep 4, 2012 | 01:45 PM
HudsonFalcon's Avatar
I have the Torque Solutions short shifter, works base and under hood bushings coupled with the Redline cocktail and it's definitely better than stock but there's still some notchy shifts. I guess having a little grinding is a fact of life with the X's tranny.
Old Sep 4, 2012 | 01:54 PM
ogrenator's Avatar
Mine is only notchy in 3rd when its cold...but goes away after 5 mins....its still mechanical though but not notchy anymore...gonna do the redline mix at some point with bushings
Old Nov 8, 2012 | 08:16 PM
jeremy52048's Avatar
hey guys what does a weighted shift knob do ? i feel like i would love one.
