Sponsored by:
Sponsored by: CARiD
More Power/Tq
Old Oct 10, 2012 | 07:16 AM
Orodi's Avatar
More Power/Tq
This maybe the wrong section but I am looking for some opinions. Right now I am sitting at 326/330 in my GSR. Im looking to hit 425-450hp no E85. Right now I have done:
FMIC
UICP
LICP
Intake
Turbo back exhaust (test pipe)
Grimspeed BC
Stg1 Clutch
CMC upgrade
I am planning on 1,000cc Inj and 340lph pump.
Im trying to maintain as much drivability as i can. Thoughts?
Old Oct 10, 2012 | 07:29 AM
Kracka's Avatar
You'll need an aftermarket turbo too. MAP EF2 with cams or MAP EF3 would get you there on 93-octane pump gas. You'll also wanted manifolds and a ported throttle body. 340 pump is overkill, a Walbro 255HP should support your goals just fine.
Check out my build for ideas:
https://www.evolutionm.net/forums/ev...-pump-gas.html
To maintain as much drivability as possible though stay away from cams, lightweight flywheels, and aftermarket clutches for as long as possible. Personally, my clutch is still holding perfectly at 47k miles.
Old Oct 10, 2012 | 09:20 AM
Orodi's Avatar
How big of a turbo? What will the stock turbo get me to? I had to swap clutches so I did a stage 1 excedy. It drives fine with that in there.
Old Oct 10, 2012 | 09:23 AM
Kracka's Avatar
Anything more than 350whp on the stock turbo with stock cams is pushing it. I got mine to just over 350 before swapping to the EF2.
Old Oct 10, 2012 | 10:17 AM
10evoxgsr's Avatar
U could also go with a fp green or a bbx lite by cbrd. Either one of those turbos or the map ef2 should get u to your goal
Old Oct 12, 2012 | 05:22 PM
Orodi's Avatar
Gotcha, so new turbo it is lol. My tuner is awesome and he knows exactly how I drive so he tunes the car to me as opposed to a HP number. I am basically looking to push as close to ,my goal without over kill. I dont want to cut corners just not buy $9000 in parts when I only needed $2,000
Old Oct 14, 2012 | 08:13 AM
BaumBizzle's Avatar
$2k in parts on an Evo isn't much these days, I think I'm sitting somewhere in the $12k range
Old Oct 14, 2012 | 08:56 AM
Widoww's Avatar
Lol ya me too..12k for parts ..haha
Old Oct 14, 2012 | 10:13 AM
Energie's Avatar
Fp red will hit your goals
Old Oct 14, 2012 | 02:29 PM
TheBlade's Avatar
Wow, that's crazy 12k for the stuff in your signature? That's paying way over retail and paying a crazy lot for labor
Old Oct 14, 2012 | 04:22 PM
BaumBizzle's Avatar
twin disc was $1500 plus CMC and install of $1k, add springs w/ install, and two tunes…theres $4k right there…most of my stuff was off the forums
Old Oct 14, 2012 | 09:04 PM
TheBlade's Avatar
Oh bunch of stuff not listed in your sig.
All the mods in my sig + a set of rota's and I'm at $2900, but I've done all the labor myself for install of everything. Guess that's where I'm saving quite a bit
Old Oct 14, 2012 | 10:11 PM
SRToad4's Avatar
Jason, reading the same thread I am haha.
Old Oct 15, 2012 | 09:34 AM
CBRD's Avatar
we would be more than happy to help if you need anything!
cheers
CB
AJ18
Cobb AccessPORT
Nov 18, 2019 08:01 AM
Konakev
Oct 15, 2016 05:57 PM
Ryan Kato
Aug 21, 2015 02:37 PM
polish_pounder
Feb 4, 2014 03:51 PM
mmack104
May 18, 2013 09:53 AM
