Sponsored by:
Sponsored by: CARiD
AEM FailSafe Gauge?
Old Nov 14, 2012 | 04:49 PM
HDGamer's Avatar
AEM FailSafe Gauge?
Hey guys, i'm looking for a good 2-1 gauge. Rather then having multiple gauges everywhere, I just want one that reads boost and AFR. Is the Failsafe the only available one?
Also is there any reason to even get the boost and wideband separately now with the failsafe out? The failsafe is the same price as both and comes with more features.
Old Nov 14, 2012 | 05:16 PM
JReid's Avatar
Well Zeitronix has the LCD screen thing that can display all kinds of readings. I like that idea, just don't want to spend the coin.
Old Nov 15, 2012 | 10:45 AM
Kouki Monster's Avatar
Interested in this as well. Couldn't find much info on these
Old Nov 15, 2012 | 10:48 AM
XTR Performance's Avatar
Let me know if you guys have any questions. The AEM Failsafe gauge is a very popular gauge. We sell about 4 a day!
-Chris
Wideband Air/Fuel and Boost in One Gauge!
The Wideband FAILSAFE Gauge provides the ability to accurately tune AFR, while actively protecting your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy if it runs lean.
The Wideband FAILSAFE Gauge is a Universal Exhaust Gas Oxygen (UEGO—“you-way-go”) controller with an internal boost sensor, an internal data logger and a full color Organic Light Emitting Diode (OLED) display. It includes technology to activate a failsafe strategy in the event AFR falls outside of a user-defined operating window. If the AFR falls outside of the set operating window, the Wideband FAILSAFE Gauge triggers a user defined output function that can save an engine from catastrophic damage.
WHY YOU WANT ONE
This product is a must have for all tuned performance engines, either forced induction or naturally aspirated, fuel injected or carbureted. Any high performance vehicle owners who want a highly accurate AFR tuning tool with logging and a protection strategy that can save an engine from catastrophic failure will want this FAILSAFE device.
WHAT IT DOES
After the engine is tuned and a safe operating window of AFR is established, the Wideband FAILSAFE Gauge continually monitors AFR and boost or vacuum to make sure that AFR does not fall out of the defined operating window at a given boost or vacuum level. If the Wideband Failsafe detects an out of range AFR reading, the gauge triggers a low side output (ground signal with a 1.5 amp draw max) that can save your engine from catastrophic damage.
Use the gauge’s intuitive software to configure the low side output, create a user-adjustable time delay strategy to prevent false alarms, and customize the gauge lighting to flash and alert the driver if an alarm is triggered.
iLLuZioNSmurF
May 1, 2014 11:07 PM
MRak
Mar 12, 2014 06:46 AM
Metal
Nov 7, 2012 09:24 PM
foxbear2277
Jun 5, 2012 03:14 PM
paintballproam
16
May 15, 2009 07:37 AM
