Sponsored by:
Sponsored by: CARiD
Having problems when shifting into 4th. Help please
Old Dec 1, 2012 | 11:17 AM
Oziel's Avatar
Recently when I started shifting into 4th gear. It's making this grinding noise. I'm pushing the clutch all the way down so I don't understand why it sounds like that. Help
Old Dec 1, 2012 | 11:25 AM
Chadilac88's Avatar
do you have enough fluid in your master cylinder? if you do can you see any signs of leaking around the master? also if you say pump the clutch twice then try and put it in will it stop? if it does then either your master cylinder is leaking our your slave....
Old Dec 1, 2012 | 07:42 PM
Johnr352's Avatar
Yes, I agree, also, if nothing is leaking, try bleeding the clutch line.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
Llew
Nov 16, 2016 05:05 AM
weeeeeeeeee
May 17, 2016 01:21 PM
evo8power
21
Jan 10, 2016 12:07 PM
coollol123
Driving Techniques
Dec 22, 2011 05:02 PM
