Sponsored by:
Sponsored by: CARiD
Transmission oil change
Old Dec 7, 2012 | 06:23 AM
TINGER's Avatar
If you do not change this fluid yourself, be sure to have the mechanic show you your magnetic drain plug. You'll wish you changed it earlier!
Old Dec 7, 2012 | 08:46 AM
an2ny's Avatar
Originally Posted by Bojim2305
Im nearing 30k miles and planning to do trans oil change. . Any recommendation on what brand of oil aside from oem. And how many miles should i change transfer case and rear diff oil?
Check out this thread, I am putting a table together that may help you.
https://www.evolutionm.net/forums/ev...cations-4.html
Old Dec 7, 2012 | 09:57 AM
ZLAYER's Avatar
Look at jacks transmission tech articles for the drain/fill procedure for the Tcase. Hollywood has good write ups on this or the other forum. Do all the fluids at once (trans, Tcase, & both rear dif fluids. There is a ton of info on how to do this on this and the other forum. That being said, it still wasn't easy. In theory it's easy, but I found it to be quite tricky compared to other drain/fills on my other cars. T-case sucked because the fluid starts trickling out immediately as you are filling. The way it's supposed to work is that you fill until it starts trickling out, then when it's done the level is correct. So follow the "Jacks tech article" or meticulously measure how much you drain, and fill Vs. how much pours back out. Get it wrong and kiss your Tcase or rear diff goodbye. Get it right and save a butt load of cash. Let me know if you have more ?s or concerns.
Old Dec 9, 2012 | 01:17 PM
markc's Avatar
amsoil 75w90 is the best you can use for manual transmission, doesnt heat up as much as the other oils and reduces wear on the gears
Old Dec 9, 2012 | 07:33 PM
Johnr352's Avatar
There are so many posts out there regarding different trans fluid options. Amsoil is one, Redline another, Motul, Diaquen, etc. I suggest you read up on everything first.
As to your statement regarding oil temps being lower with Amsoil, is that documented? Is that something you know for a fact? We use a transmission temp gauge and haven't found that to be necessarily true at the race track and so I'd be very interested to better understand from where, exactly, that information originated. Thanks
WW13X
Jan 5, 2017 03:33 PM
RrK
Lancer Troubleshooting
10
Aug 2, 2010 09:16 AM
doclin
Evo X How Tos / Installations
13
Jan 23, 2009 08:48 AM
DreamingReality
Oct 15, 2008 09:33 PM
gregivq
Dec 26, 2004 11:34 AM
