Sponsored by:
Sponsored by: CARiD
Squeaky noise when idling
Old Dec 22, 2012 | 10:45 PM
rheindollar's Avatar
So i've been noticing this more and more on my car and after doing some research and not being able to find anything i decided to ask. I purchased my 2012 GSR in March, I currently have 16k on it *its my daily * and I hear this weird inconsistent squeaking when i'm idling. I clearly notice it when I park it in my garage. Around the 10k mark I noticed when I turn the car off it makes this squeak noise. thought it was the intake at first but i have no idea.. just wanted to ask around before I take it to the dealer. the car runs just fine and feels solid but this was just buggin the hell out of me since it came out of nowhere.
i found this on evo x forums http://www.evoxforums.com/forums/showthread.php?t=61854
thats definitely what it sounds like as im idling but not that extreme at all.. i hear it for about a few seconds.. then it stops and then continues. could it be the belt? water pump?
when i stick my head in the bay as its on it sounds like its coming from the exhaust manifold/turbo area..
so anyone having the same issues?
Old Dec 23, 2012 | 06:09 AM
Johnr352's Avatar
I bet it is a pulley, are not the belt, though I am a little surprised given the mileage. The pulleys are a weak point as they are made of plastic and do wear. If you do some research you can find that many (including ours) replace the pulleys with those from Hyundai, as those are made of metal and will wear better.
You can try just replacing the belt but, if it doesn't work, you'll want to go back in and change the pulleys too, might as well do both once.
Old Dec 29, 2012 | 01:35 PM
evoooox10's Avatar
A rat in your engine bay looking for a free ride?
Old Jan 1, 2013 | 09:31 PM
ILOVEBOV's Avatar
With only 16k miles on it, high chance it is the pulley like Johnr352 said, also check your tensioner as well. I had the same issue with my MR and just decided to get lighter pulleys and put less strain on the engine as well. But yea the OEM pulleys are crap! Its really a quick fix.
Old Jan 1, 2013 | 10:46 PM
genelee112601's Avatar
our evo x pulleys are Plastic all 3 is plastic pulleys
replace it with hyundai Pulley part # 25287-2C000
Old Jan 2, 2013 | 04:54 AM
Johnr352's Avatar
Should be a sticky... Thanks. Note, the tensioner pulley can be changed as well though it takes a little finagling.
Old Jan 2, 2013 | 05:40 AM
flmr06's Avatar
One of the unfortunate details Mitsu didn't pay attention to. The Hyundai pulley's are a much nicer piece, although under rare circumstances I've heard a squeak out of mine(2-3 times I'd say) which I'd probably point more towards my belts. My noises decreased significantly after switching over. Hope this helps OP!
Old Mar 20, 2013 | 10:19 PM
R0Y's Avatar
R0Y
hmm... could this noise be from the pulleys? (first part of vid)
http://www.youtube.com/watch?v=q_Cmo...ature=youtu.be
Old Jun 4, 2013 | 06:47 PM
bong09's Avatar
I have the same problem, but only when it rains or if it gets wet. I hoping to get it home at the end of the month and park her for the rest of the year. Any idea what it is?
Old Jun 4, 2013 | 07:33 PM
naveed80's Avatar
It's probably a pulley most likely, cars under warranty get it checked out, do not pay them for this!
Old Jun 6, 2013 | 08:37 PM
xXevo8RavenXx's Avatar
i dont think the tensioner would being letting go at so low of mileage?
TxFAkuma
45
Feb 24, 2017 05:19 AM
Simmons
Jan 20, 2014 04:21 PM
Puerto_reCOn
Lancer Troubleshooting
Nov 19, 2011 10:39 AM
LooneyToon
May 11, 2009 05:25 AM
omniprobe
Jan 9, 2008 10:16 PM
