Sponsored by:
Sponsored by: CARiD
What to do, what to do
Old Jan 1, 2013 | 02:59 PM
doghead's Avatar
I would just save up for a tune or you could prob buy a used accessport on here for around 300. With just a protune you should be around 300whp on a dynojet
Old Jan 1, 2013 | 05:25 PM
Sunwalker12's Avatar
I would use a Cobb but it leaves a footprint in the ECU. Its only $150 an hour and he is using EvoScan. I think I'll probably just get the UICP and spend the rest on a taxtrix 2.0 cable should I ever need to re-tune or log. I already set aside money for the tune, which shouldn't take more than an hour (never spent more than 40 minutes on a dyno w/ the mustang).
Old Jan 1, 2013 | 05:34 PM
ILOVEBOV's Avatar
Well, the cone intakes are fine and like others have said won't cause much more HP gains once tuned i'd say maybe at the most a 7-8hp diff. If I were you I would search around the forums and find a nice cat back with a test pipe. If not you can always see how much a custom exhaust would set you back at your local muffler shop. I got mine all customized at my friends muffler shop cat back from my open down pipe with a 80mm titanium single tip for around $275.
I have upgraded titan fuel rails, 96lbs RC injectors, open down pipe, custom exhaust cat back, stock turbo, turbonetics BOV, waste gate actuator thats holds about 29-30psi, cone intake, stock ECU ready for E85. With my current tune i'm putting down 340hp/329tq at 22psi.
Old Jan 1, 2013 | 05:47 PM
Thats some impressive power for just a couple mods man.
Old Jan 1, 2013 | 09:00 PM
ILOVEBOV's Avatar
Thanks man, I'm all about maxing out in power but I want to keep my MR a safe daily so if I would want more power in the future I would just get 272 or 280 cams and some titan cam gears and get the twinscroll garret gt35 which is pretty much a direct replacement bolt on turbo and could squeeze a good 480-520hp to the wheels prob around 24psi. The evo is my daily, then I have my toys for bigger power!
But yea like I said before, search around the forums for a nice test pipe or full cat back and for a few extra bucks get an open down pipe Its all about the right mapping/tune and ofcourse proper quality parts to put up with the more demand.
mobilman
Nov 25, 2010 12:01 PM
ProjectMayhem
Jun 1, 2009 10:47 PM
SurferX
14
Jan 15, 2008 01:59 PM
Tha Shocker!
24
Oct 2, 2007 10:01 PM
xLaNcErEvOx
Feb 4, 2007 11:07 AM
