Sponsored by:
Sponsored by: CARiD
Hit the curb :...( Need help pls
Old Jan 22, 2013 | 07:23 AM
whiteEvo08Y's Avatar
Hope it can be a cheap fix for you. Good luck
Old Jan 22, 2013 | 07:32 AM
bphx123's Avatar
Originally Posted by Johnr352
Not to belabor the obvious but I suggest the car is a bit broken... LCA, or knuckle (maybe the bearing too, but I'd be surprised.) You may want to drive it a bit less until you get it fixed, and certainly don't drive it fast.
Originally Posted by Iowa999
If the ASC ECU is reading that the steering wheel is turned but all four tires are turning the same speed and the lateral g-sensor also says that the car is going straight ahead, you will get an AWC code. Fix the alignment and, odds are, the light will go out.
And stop driving the car.
Old Jan 22, 2013 | 09:18 AM
Iowa999's Avatar
Originally Posted by lancera
haha i just dropped off the car at sears auto
Why on earth would you do that? Wouldn't it be easier to wipe off your prints and report it stolen?
Old Jan 22, 2013 | 09:43 AM
lancera's Avatar
update. found out that the inner and outer tie rods are bent.
Old Jan 22, 2013 | 10:59 AM
bphx123's Avatar
what's the damage $ wise ?
Old Jan 22, 2013 | 11:23 AM
lancera's Avatar
like around 400-500
Old Jan 22, 2013 | 11:45 AM
mikyftw's Avatar
ouch... good luck
Old Jan 22, 2013 | 11:54 AM
lancera's Avatar
Originally Posted by mikyftw
ouch... good luck
if i didn't need the car so bad, i would of order it online.
Old Jan 23, 2013 | 11:29 AM
Iowa999's Avatar
<- [rereads Post #9 and then high-fives himself with a smug grin]
Old Jan 23, 2013 | 11:43 AM
Jason S-9's Avatar
^ haha good call
Old Jan 23, 2013 | 05:49 PM
lancera's Avatar
haha, btw the replacement of inner and outer tie rods and alignment is 370 from the dealer.
b16a95eg
Jun 3, 2017 04:56 PM
casper980
Aug 30, 2015 12:14 AM
ezzey
Dec 6, 2012 09:58 PM
Jamesm331
Feb 29, 2012 08:32 AM
Lightsped
Jul 14, 2010 11:41 AM
