Sponsored by:
Sponsored by: CARiD
New exhaust/Intake "studdering"
Old Mar 21, 2013 | 02:16 PM
mmack104's Avatar
Okay so I just had an AMS intake and AMS Turbo back exhaust with test pipe put on and used the Cobb Accessport stage 2 AMS map for it and all is well EXCEPT when I go WOT in 2nd gear it "sputters" all the way through 2nd gear, is it something related to my spark plugs? I do not believe that my clutch is slipping at all btw. Please help
Old Mar 21, 2013 | 02:20 PM
Ev0ikon's Avatar
Does the sputterings change with different plug gaps?
Old Mar 21, 2013 | 02:25 PM
mmack104's Avatar
I have not changed it at all. Got the exhaust and intake put on and reflashed it and this happened.
Old Mar 21, 2013 | 02:27 PM
Apex_Kurt's Avatar
Not really the same issue, but mine sputters too, but at low RPM's, it's fine at WOT. Cruising speeds at low RPM causes it to sputter though. I'm always having to drop a gear if It's sputtering and raise my rpm's a little.
Old Mar 21, 2013 | 02:31 PM
mmack104's Avatar
Mine is strictly at WOT, its as if the clutch is slipping but it shouldnt be at all. I believe it has something to do with the plug gap or something related.
Old Mar 21, 2013 | 02:41 PM
Ev0ikon's Avatar
Try to lower the plug gaps and report back
Old Mar 21, 2013 | 03:05 PM
mmack104's Avatar
Opinion on what i should gap them too?
Old Mar 22, 2013 | 07:03 AM
Ev0ikon's Avatar
Thumbs up
opinion on what i should gap them too?
0.020 - 0.022 "
Old Mar 22, 2013 | 09:00 AM
mmack104's Avatar
0.020 - 0.022 "
Should i just use OEM ones or buy some higher performance ones now?
Old Mar 22, 2013 | 09:56 AM
kalpakiotis's Avatar
physics at work
If you let off the throttle or accelerate it will also go away. You are just hitting a harmonic of the exhaust.
Old Mar 22, 2013 | 10:13 AM
Ev0ikon's Avatar
On your setup stock heat range or a step colder is ok.
Old Mar 22, 2013 | 11:52 AM
Jerm6908's Avatar
Know that feeling same happens to me....Gotta love 45 mph speed limits where i live yes i go 50 mph but rather be in 5th then 4th doing 50
Old Mar 24, 2013 | 10:28 PM
SUBIIKLR21's Avatar
I had a similar issue when I first got my X, when I would go wot it would sputter terribly. At that time I had no modifications, come to fun out I had fouled plugs. After replacing them I had no more issues with that.
mmack104
Mar 27, 2013 11:40 PM
YuLost2x
Sep 25, 2012 04:31 AM
st0mp860
Northeast Region
Aug 6, 2012 07:00 AM
boczo777
Dec 11, 2009 02:10 AM
Brsox10288
Dec 6, 2009 12:25 PM
