Sponsored by:
Sponsored by: CARiD
Burning up oil
Old Apr 2, 2013 | 06:42 AM
foxhound1421's Avatar
Burning up oil
I have a 2012 Evo X MR with about 5800 miles on it. I mainly drive the car on weekends and sometimes to the store here and there due to having a company car. The only mod I have on the car is a ETS Intake.
The other day I was driving and the car seemed like it was acting up and I started to check the fluids and I noticed that the oil was like 2.5 qts low. I just changed the oil around the first of the year. I looked in the engine bay and I haven't notice any oil leaking anywhere. I would take it to the dealership but the dealership is like a 4 hour drive from where I currently live.
Any suggestions on what I should be looking for or what could be happening?
Thanks
Old Apr 2, 2013 | 06:48 AM
Iowa999's Avatar
If it's not dripping and not blowing blue smoke, then maybe the people who changed your oil put in too little. Keep an eye on it for a few weeks before freaking out.
Old Apr 2, 2013 | 07:00 AM
I remember checking it about a month ago and it was a little low and I topped it off.
Old Apr 2, 2013 | 07:12 AM
Crester's Avatar
How is your car "acting up"? Also... are you letting the car settle before checking the oil level?
Old Apr 2, 2013 | 07:19 AM
It just seemed weird to me, nothing really in particular. Maybe it was the idle, honestly I can't remember. Yea I checked it like 30 mins after I parked it.
Old Apr 2, 2013 | 08:00 AM
Crester's Avatar
If you can't even say what the problem is... your imagination may be playing tricks on you... lol
Old Apr 2, 2013 | 09:15 AM
Yea but it still doesn't explain why I would be burning up that much oil. I'll just keep watching it.
Old Apr 3, 2013 | 04:02 AM
Kendogg's Avatar
Where did you get your oil changed last? The Evo has a little ring that goes with the oil plug. When the plug is tightened it crunches the ring giving it a seal. The rings are suppose to really only be used once and should be changed out with each oil change. Using the same ring a second time may cause an oil leak. Do you have any leaks under the car when it is parked?
Old Apr 3, 2013 | 04:41 AM
evokid4life's Avatar
are you checking your oil right after you drive it?
because you should wait about 10-15 mins after you drive it to check your oil so all the oil can drain down into the oil pan
Old Apr 3, 2013 | 07:00 AM
I had my oil changed by the dealership around the first of the year. Also I haven't seen any oil leaking under the car. I'll jack it up today and see what i can see from under the car. Also, like I said in a previous post that I waited 30 mins to check the oil.
Old Apr 3, 2013 | 07:15 AM
Jerm6908's Avatar
Just a tip change the drainplug washer every other oil change if you haven't been already
Old Apr 3, 2013 | 02:14 PM
SD_Lurker's Avatar
to answer your question not that's not normal. You shouldn't be burning that much oil. Granted they will burn oil but not that much.
eveten
Nov 22, 2014 10:32 AM
formerSTIowner
Sep 3, 2014 05:37 PM
snow
Jun 19, 2013 07:51 AM
evo_soul
Lancer Engine Tech
Jun 14, 2011 08:58 AM
diameters
21
Apr 10, 2008 07:13 AM
