4wd service required
Done!
Bought my vehicle as a certified pre-owned vehicle with 37,213 miles on it. At 43,000 miles, vehicle began having malfunctions with the All Wheel Control system and Electronic stability control hydraulic pump. This should be an item covered under the 5 year/60,000 mile warranty, however, Mitsubishi states that it is NOT covered, even though it is part of the power-train, and required to work for vehicle stability and safety. Mitsubishi has continued to refuse to warranty the pump. This is not an isolated issue, and there have been dozens, maybe hundreds of other cars with the exact same malfunction, many of these were turned away by Mitsubishi even while they were under the power-train warranty.
The above is correct and we have two parallel threads on this issue: https://www.evolutionm.net/forums/ev...-warranty.html and https://www.evolutionm.net/forums/ev...-warranty.html
So I'm shutting this one down.
Hughett
Feb 3, 2014 03:03 AM
