Sponsored by:
Sponsored by: CARiD
What size Intercooler?
Old Apr 22, 2013 | 05:57 PM
richdegrave's Avatar
I went from my 2006 evo 9 mr to. 2013 evo mr with 400 miles on it. Pretty much already about to be a full bolt on car already
Old Apr 22, 2013 | 06:11 PM
joseph143's Avatar
big
Old Apr 23, 2013 | 08:09 AM
bigmatt33's Avatar
I'm thinking the 3.5" would probably work best. I will either go with the AMS or ETS. Those brands seem to be the best quality for the buck. Some brands IC I have found cost like twice as much as those.
Old Apr 23, 2013 | 09:09 AM
ETS Michael's Avatar
Really depends on your goals with the car. We recommend the 3.0" for a stock replacement at moderate boost levels or with a customer who runs a 30R or something similar. The problem with the stock frame turbochargers is that most customers will run them out of their efficiency range which creates a lot of excess heat. The larger intercooler like the 3.5" does a much job at keeping intake temps to a minimum. The 3.5" will also fit behind the crash beam with no modifications. In my opinion you can't go wrong with the 3.5". If you plan on running a larger turbo setup down the road a 4.0" would be preferred for flow reasons, you won't notice an increase in lag on the stock turbocharger (We tested this with a 5.0" intercooler and full 3.0" piping and didn't increase the lag).
Hope this helps!
Thanks,
Michael
Old Apr 24, 2013 | 12:13 AM
CosmotheJTAC's Avatar
Hope this helps!
Thanks,
Michael
+1
I've been running the 4in on my 2011 X and haven't run into any issues with lag. I personally went with the 4in because I have plans to upgrade the turbo. Can't beat ETS customer service either.
Old Apr 24, 2013 | 08:48 AM
Thanks Man! We appreciate the support.
Michael
Old Apr 24, 2013 | 09:21 AM
deadbeatrec's Avatar
just purchased an ETS 3.5" and its not in the car yet. i felt as though 3.5" is the best of all worlds. flow, efficiency, heat dispersal and power. anything more than 4" and you have to wonder, is that 4" core really getting cold all the way though? is it more effient?
AMS or ETS 3.5" has my vote all day for small and larger turbos.
SSMCL9
May 23, 2015 02:59 PM
JonGonzo
Jan 15, 2014 01:58 PM
GO ON 3
Toronto Lancer Club
42
Feb 25, 2012 07:16 PM
motion3131
Jan 15, 2012 09:34 PM
BigNuts
Jul 24, 2011 03:37 PM
