Sponsored by:
Sponsored by: CARiD
For those of you with ACD pump failures (merged)
Old Feb 2, 2014 | 11:05 AM
  #256
Thomar's Avatar
Any nice success stories with rebuilding these?
Old Feb 4, 2014 | 06:55 AM
  #257
ignitionr34's Avatar
Anyone make a pump delete kit? It seems like the best options are relocating or removing.
Old Feb 4, 2014 | 07:10 AM
  #258
Iowa999's Avatar
Removing? Have you done much driving of an X with an open center and open rear? Pull the fuse and try it for a while before you suggest removing the pump.
Even if you intend to replace the rear diff with a mechanical (which is what is done for rally), you'll still have an open center and that will suh ... um ... be lousy.
Old Feb 4, 2014 | 10:16 AM
  #259
wiretap's Avatar
Originally Posted by wiretap
I'm at around 72k miles.. I daily drive my Evo, even in the Michigan salty winters. I get an underbody wash weekly when they salt the roads. Knock on wood, mine is still holding up. It is however making a little louder whining noise than usual in my first few turns I make when the car is still warming up. No codes thrown and it still appears to be working. I now have a truck to drive in the snow, so I will be causing less wear and tear on the pump.
I spoke too soon. My pump appears to be on its last leg. I'm just over 75k miles now and the pump does not like the cold. I took it out for a drive when I was fixing a half-shaft on the Hummer, and the pump is now throwing a code and not working when it dips down below 20F degrees. I'll probably order the rebuild kit this spring.
Old Feb 4, 2014 | 11:28 AM
  #260
Iowa999's Avatar
Pull the power to it now. No need to risk killing the motor, which is often impossible to fix.
Old Feb 5, 2014 | 06:45 AM
  #261
wiretap's Avatar
Thanks, will do.
Old Feb 5, 2014 | 01:26 PM
  #262
imhenryd's Avatar
yeah mine is busted, and from how common of a problem i have started to see this is, its ridiculous that the only options are rebuild kits or spend $2,000 for a new one! any ideas apart from filing that complaint?
Old Feb 5, 2014 | 01:27 PM
  #263
imhenryd's Avatar
how do i pull the power to the pump?
Old Feb 5, 2014 | 01:52 PM
  #264
ChUt26's Avatar
Pretty sure there is a fuse for it.
Old Feb 5, 2014 | 01:55 PM
  #265
imhenryd's Avatar
cool, now i just have to find out which one
Old Feb 5, 2014 | 05:20 PM
  #266
Iowa999's Avatar
Looking at the fuse box from in front of the car, it's the really big black relay on the left side, about three-quarters of the way towards the windshield. Its label (on the back of the lid) is AYC PTC.
Old Feb 12, 2014 | 08:27 AM
  #267
Dace's Avatar
I successfully rebuilt my pump using the kit sold by ACD Tuning.
Make sure you purchase the testing/bleeding tool he offers as well, there is no way to bleed the system correctly without it.
The bleeding process is not as hard as it seems like it will be, there is a great post over on evoxforums that explains how to do it.
Old Feb 12, 2014 | 09:48 AM
  #268
EvolutionTheory's Avatar
I had mine replaced at 35K miles under warranty. I was told I was lucky because they covered it under the bumper to bumper and it wasn't covered under the drivetrain that goes up to 50K miles. I'm guessing the cause was cold weather because it failed on a sub zero day. The new one is fine and I'm currently at 82K and we have had days around 0 degrees Fahrenheit or lower plenty.
Old Feb 19, 2014 | 08:41 AM
  #269
CaptainAsia's Avatar
Yeah, so I got a reflash at the dealership and it seemed to fix it, sort of. It just flashes every so often and the comes back to life. Has this happened to anyone else? Only warm weather seems to make it flash, cold weather doesn't seem to kill it.
Old Feb 19, 2014 | 08:59 AM
  #270
Iowa999's Avatar
When the fluid is cold, it's less likely to leak behind the plate inside the pump. As soon as it warms up, it leaks and throws the code. If this is true for your pump, then the cold-start reflash won't do squat.
In other words, your pump is (probably) what I call mostly dead. Not all dead. Just mostly dead.
