Sponsored by:
Sponsored by: CARiD
For those of you with ACD pump failures (merged)
Old Nov 11, 2014 | 10:43 AM
  #421
coryl's Avatar
Originally Posted by Mystykalbaby
That's fresh to death. Who did it?
Thanks, that's my car with relocation kit from Autotorque. I'm very happy with the final results and now I don't have to worry about lines or my expensive pump.
Old Nov 14, 2014 | 02:50 PM
  #422
almost2009's Avatar
Question: My light went off when accelerating. Was fine all day until I accelerated hard. Could it be possible because I'm on a loaner tire and its a different size? I don't think the pump is bad. When I turn on my car I have awc, but as soon as I put it in drive and move forward the light comes back on..
And how long can I drive with a faulty awc pump if its bad?
Old Nov 15, 2014 | 05:41 AM
  #423
Thomar's Avatar
You can drive indefinitely with a bad pump, but driving with a tire that's a different size than the rest on an all wheel drive car can damage the drivetrain.
Old Nov 15, 2014 | 09:49 AM
  #424
coryl's Avatar
Do not drive an AWD vehicle with a different size tire as it WILL damage the drivetrain including probable damage to the transmission as it will be in a constant state of stress. I'm sure that's the reason for your codes although I'm seriously hoping for your sake that it's your pump failing it will probably be the cheapest to fix. Buy yourself 4 new (same size/tread/brand) tires before you drive another inch and also check the codes. And if you have warranty you might not want to say what you've done. Here's hoping that things work out for you.
Old Nov 15, 2014 | 12:10 PM
  #425
almost2009's Avatar
It's the same tire, almost same amount of wear, and still pulled straight. I don't think it was the tire, but that has been situated. It's definitely the pump.
-Thanks
Old Nov 22, 2014 | 12:24 PM
  #426
Thomar's Avatar
Word has it that Mitsubishi is going to cover the pump under the power train warranty, and reimburse anyone who replaced the pump while still under said warranty.
Word also has it that the replacement pumps are an upgraded version.
So, good news, folks.
Old Nov 22, 2014 | 01:01 PM
  #427
jsaviour84's Avatar
my car has 50k on it but its an 08. I'm guessing I'm out of luck?
Old Nov 22, 2014 | 01:56 PM
  #428
Thomar's Avatar
I don't know, hopefully Mitsubishi will release a bulletin soon regarding this.
Old Nov 24, 2014 | 08:04 AM
  #429
Veronica's Avatar
I hope Mitsu does The Right Thing and takes care of their customers... You know, to build loyalty... [shrug]
Old Nov 24, 2014 | 01:17 PM
  #430
ChipperEvo's Avatar
so there is a chance they will cover it under the 3 year/36K powertrain? Shouldn't this be the drive train warranty?
Old Nov 24, 2014 | 01:53 PM
  #431
hoobastnk90's Avatar
yea it should be covered under the 3/36 warranty but it usually is not covered under the powertrain warranty
Old Nov 25, 2014 | 06:18 PM
  #432
Thomar's Avatar
The bumper to bumper is 3 years, the power train warranty is 5 years.
Old Dec 5, 2014 | 09:06 PM
  #433
cbr1000's Avatar
Any updates, do you feel like you heard this from a reliable source and it's actually going to happen? I can't find anything online about mits covering the pump.
Old Dec 6, 2014 | 09:14 AM
  #434
Thomar's Avatar
A local guy that works for a dealership is who told us.
Old Dec 7, 2014 | 10:45 AM
  #435
FrenziedTom's Avatar
08 EVO X GSR 27k miles...Pump died 2 days ago in -18 degree weather.
