Sponsored by:
Sponsored by: CARiD
which downpipe?
Old May 14, 2013 | 08:24 PM
mmack104's Avatar
which downpipe?
Right now I'm currently running an AMS downpipe but I am considering switching to the ETS downpipe with the dump. Looking for opinons on this.
Old May 14, 2013 | 08:28 PM
cdmassee's Avatar
Opinion....
Great downpipe...
too much money.
MAP makes about the same downpipe... much less money.
http://www.maperformance.com/map-sta...l#.UZMAnSvSO_E
This is the downpipe I have and The welds on it are perfect and I expect it to last as long as I need it to.
Old May 14, 2013 | 09:42 PM
MR_mike's Avatar
Hey if you decide to get ride of the AMS down pipe let me know I'm looking for one
Old May 14, 2013 | 09:47 PM
XTR Performance's Avatar
If you decide to go ETS open dump.... Great downpipe. We love ... ETS products!
-Chris
Last edited by Iowa999; May 15, 2013 at 12:02 PM. Reason: tech forum, dude; no vending
Old May 15, 2013 | 06:04 AM
MadBoostedEvo's Avatar
Stick with your current DP. It's made out of cast stainless steel, that won't crack over time.
Old May 15, 2013 | 07:24 AM
ChrisCarey's Avatar
Originally Posted by cdmassee
Opinion....
Great downpipe...
too much money.
Thanks for the referral! These have been available for years and to the best of my knowledge we had one that cracked but the prompted us to change our design and thus far we haven't had another issue!
Old May 15, 2013 | 07:48 AM
mmack104's Avatar
Alright one question, what are the pros and cons of having the open dump rather than recirculating?
Old May 15, 2013 | 08:38 AM
lippy1306's Avatar
Open dump will be louder than recirculating and you won't pass emissions since you will be bypassing the cat. From what I've heard power gains are supposed to be slightly higher with an open dump.
Old May 15, 2013 | 09:07 AM
bmh11evo's Avatar
PM sent for downpipe!
Old May 15, 2013 | 10:21 AM
lippy1306's Avatar
I doubt you'll see any significant gains by switching out the downpipe. It seems like a waste of time and money to be honest.
Old May 15, 2013 | 11:09 AM
FearDavid0586's Avatar
I LOVE my open dump, but prepare yourself because under WOT it sounds crazy!!!(in a good way) I love going under overpasses and putting it to the floor, screams like banshee
ETS's quality and customer service are both excellent
But, if I already had a decent DP installed, not sure if I would want to switch. The install is a huge pain, paying to have it installed is too $$$ and the performance different will probably be unnoticeable. but, if your a fan of the open dump sound, go for it!!!
Hope this helps
Old May 15, 2013 | 03:36 PM
ETS Michael's Avatar
Hope this helps
I agree with you. On stock turbochargers you won't see a huge difference between the VTA and the Recirc. You will max out the turbocharger before a restriction happens. On a larger stock frame turbocharger you may see a gain, but you would need something restrictive in your exhaust system like a stock catalytic converter.
We have a lot of customers that get the dump version and find out it's just too loud. The recirculated downpipe will sound similar to factory and increase exhaust flow by removing the restrictive section in the o2 housing. We also separate the gasses which eliminates excess turbulence at the turbo outlet and helps with overall exhaust flow.
Thanks!
Michael
Old May 15, 2013 | 04:14 PM
ikt's Avatar
ikt
all three are similar
all three are very high quality and made by reputable companies that stand by their stuff
buy the one you like
Old May 15, 2013 | 04:28 PM
tellme718's Avatar
Wish MAP was closer to me.
Old May 15, 2013 | 04:32 PM
ikt's Avatar
ikt
You're about 1700 miles closer than I am!
