Sponsored by:
Sponsored by: CARiD
E85 for 650whp
Old Jun 1, 2013 | 09:24 PM
VEGASGTR's Avatar
E85 for 650whp
Newbie here.
I know a lot about GTR's ..Trying to learn about these evo x's
I owned a 09 GTR making 840whp on E85.. car ran 9.5s@151 in Las vegas..Car was sold last month and I picked up a nice looking evo x.
I called Cobb in CA ..they said running 2000cc + injectors WILL not run smooth.. car will drive a little rough. Anyone here have a formula for running large injectors on E85 and perfect drivability? stand alone?? My GTR ran soooo smooth on E85.
IF i cant get a smooth running car i will have it tuned on 100octane and prob keep the car at 575whp .. i really love E85 (3.29 a gallon)..
here is the info on it from the seller...
ALRIGHT JUST TESTING WATERS 2010 EVOX GSR WITH 19,000 MILES ON IT . .FULLY BUILT, . .BUILT N TUNED BY THE BEST @ '' AMS PERFORMANCE''.THE CAR MAKES 490WHP ON PUMP 93 GAS, . . .AND 600WHP ON RACE FUEL,..CAR CAN MAKE 700WHP OR SO W BIGGER INJECTORS!
MODS
FULLY BUILT AMS STAGE 1 SHORT BLOCK
AMS spec JE pistons
Manley I beam Rods, Rod
ARP 4B11T Head Stud Kit
cosworth headgasket
AMS Spec TMP Cams by Kelford for Evo 10
Kelford EVO X 4B11 valve springs
AMS EVO X Lower IC Pipe Kit polished w/ TiAL QR Blow Off
AMS EVO X Front Mount intercooler
AMS EVO X 900X vband Turbo kit
precision 6265 ball bearing turbo,
TIAL 44mm vband wastegate
AMS EVO X Racing Series 3" Catback Exhaust Single Tip
AMS EVO X / 09 Ralliart Resonated Test pipe section
MITSUBISHI 4B11 ALUMINUM VALVE COVER
Magnus Motorsports EVO X Clutch Master Cylinder Upgrade Kit
MITSUBISHI - EVO 8/9 CLUTCH MASTER CYLINDER
Injector Dynamics 1200cc High Impedance Injectors
FUEL LAB fuel return sytem
Aeromotive 340 LPH fuel pump Double pumper setup
AMS EVO X Under hood Shifter bushings
EXEDY twin disk
SHEP transfer case
OPTIMA red top battery
INTERIOR
AEM Wideband Air/Fuel Gauge
AEM Boost Gauge -30 - 0 - 35 PSI,
AEM Oil Pressure Gauge 0-150 PSI
Auto Meter Black Gauge Cup, 52mm
Cobb Access Port
apexi turbo timer
kenwood excelon double din w navigation n back up camera
kenwood excelon speakers
kenwood excelon amp
kenwood excelon sub
viper alarm w phone remote
AMS shif knob
JROD DRL wiring kit
EXTERIOR
AMS carbon fiber roof
SEIBON carbon hood
SEIBON carbon lip
SEIBON carbon rear lip
SEIBON duluck style carbon trunk
AMS shorty antenna
8000K low beam hids
8000k foglight hids
WHEELS
VOLK TE37 SL 18X9.5 +22
BRAND NEW NITTO INVO TIRES 275-35-18
VOLK RED LUG NUTS
SUSPENSION
OHLINS road n track full adjustable coilovers w pillowmounts
HOTCHKIS front n rear sway bars
stainless brake lines
CAR HAS TWO MAPS ON THE COBB, . ONE ON 93 OCTANE @ 28PSI, 2ND ONE IS FOR RACE FUEL @ 36 PSI.
Old Jun 1, 2013 | 09:40 PM
Alpha X's Avatar
I was wondering why you sold your GT-R
Old Jun 1, 2013 | 10:30 PM
0mega's Avatar
UH....why get rid of the GT-R? Godzilla is king.
Old Jun 1, 2013 | 11:00 PM
goCJgoCJgo's Avatar
I just sent you a PM
Old Jun 2, 2013 | 02:50 AM
VEGASGTR's Avatar
I am in the process of getting a bigger house...Sold the GTR for a larger Down payment.
I plan on keeping the evo x for 6-9 months and get back into a GTR .New Goal will be 8.9s
If i like the evo x ..I will keep it as godzilla's sidekick.
just hoping i can get the car to drive near stock at 650whp on E85.
the guy who PM'd me..Ill get back to you tomorrow.
Old Jun 2, 2013 | 05:23 AM
mshilto89's Avatar
By "near stock", do you mean "reliable"? I'm no expert but anything over 500 hp to me and it seems like you're kin of throwing reliability out the window.
And this is just me, but I was always kind of hesitant about buying a car that has already been modded, let alone built. Either way, good luck with everything
Old Jun 2, 2013 | 06:06 AM
EvoX2NR's Avatar
I didn't have any problems with big injectors on my old X. It had an ETS 6262 kit and a full build. On ethanol it drove perfectly (minus the lag for DD). I don't know if it was due to the fact that I tune my own cars and nit picked it or not, but it was fine. I actually liked the way that the 2150's ran so much, that I ran them on a stock turbo/motor setup on my 8 until I reached my goals for that configuration. I also just did an SD tune on another 8 with 2150s on his pump gas, stock turbo (for now) configuration, and everything drives just fine for him as well.
For the fuel system on my X I ran:
FIC 2150s
Buschur Double Pumper
Boomba fuel rail
Hopefully this helps
Old Jun 2, 2013 | 06:59 AM
black E's Avatar
FIC 2150s
Boomba fuel rail
Did you have issues with emptying the fel basket or fuel starvation with the Buschur DP when under half tank?
Old Jun 2, 2013 | 07:46 AM
r34p3rex's Avatar
For a turbo as big as the one in that car, running E85 will not be a problem with 2000cc injectors. It may be a problem if you ever decide to switch back to pump gas though
Old Jun 2, 2013 | 09:29 AM
EvoX2NR's Avatar
I tuned it at just above a quarter tank to help minimize variation, so I didn't really notice any starvation. On pump they ran fine, on the 6262, and like I mentioned about the 8 that I tuned running pump on them using the car as a DD
Old Jun 2, 2013 | 08:56 PM
VEGASGTR's Avatar
I think the issue is the cobb tuning ability. I will be talking to Mitch@ cobb in CA tomorrow..
If he thinks it will run rough.. I will just get a tune for 100 and call it a day.
I would like a 130 trap on 100
Old Jun 2, 2013 | 09:59 PM
desiromeo812's Avatar
Talk to Bakaunchi on the forum..(Jon Drenas). He has those same injectors on Marlo's car running about 700+ on e85.. Smooth as it will get drivability wise.
Old Jun 3, 2013 | 11:18 AM
mirkendargen's Avatar
There's nothing "near stock" about that car, hehe. Built engine, aftermarket (and not stock frame) turbo, etc. There definitely are people that properly dial in 2000cc injectors to be able to drive around town without stalling though.
Old Jun 3, 2013 | 11:36 AM
r34p3rex's Avatar
Yah, if it's a tuning problem with Cobb, just hit up some of the e-tuners like Hollywood_x or BakaUnchi and see what they have to say
Old Jun 3, 2013 | 11:08 PM
0mega's Avatar
Sounds like some solid goals. I too would like to have an EVO X sidekick AND a GT-R Good luck with your EVO X build, be sure to make posts about your progress.
m0nkie
Oct 23, 2017 08:19 AM
steveliu30033
For Sale - Cars For Sale
Feb 21, 2017 11:00 PM
wickedevos
Jan 19, 2016 10:55 AM
xceler8rob
Nov 14, 2015 09:19 AM
sloow hatch
13
May 25, 2013 06:56 PM
